Will this cam work with future parts
Old May 31, 2005 | 01:00 PM
98transguy's Avatar
Default Will this cam work with future parts
Currently i have a comp cams 216/220 cam , afr 205 heads (66cc) chambers,lingenfelter ls6 manifold,hooker long tubes, slp air lid. Was wondering if this cam will work when i want to add a d1sc procharger? Any feedback, and or suggestions greatly appreciated.
Old May 31, 2005 | 01:25 PM
2000 Tran Zam's Avatar
it will definately work, just depends on how hard core your future setup will be. what is the compression with your setup? thats the only problem i would see, is if you have a compression over 9.5 : 1 , which i would assume you are running 10:5 : 1 or 11:1 or higher.
once you decide to go with FI, you'll either need to lower the compression by getting diff heads, or dished pistons for FI.
