Finally made a little progress on the twin setup!!
Old Jun 1, 2005 | 10:06 PM
nitrorocket's Avatar
Default Finally made a little progress on the twin setup!!
Well, I have'nt have much time to get to the car with work and all, but I made a little progress. I finished building the forged motor, Finished my 321 stainless double slip 4 into 1 merge collectors, and welded in the motor mounts today. Now I just have to drop the motor in, Finish fabbing the headers, and start bolting all the parts on!! Hopefully I will have time to finish it by July 4th!!
Attached Thumbnails Finally made a little progress on the twin setup!!-dvc00733.jpg   Finally made a little progress on the twin setup!!-dvc00779.jpg   Finally made a little progress on the twin setup!!-dvc00780.jpg   Finally made a little progress on the twin setup!!-dvc00734.jpg   Finally made a little progress on the twin setup!!-dvc00783.jpg
Old Jun 1, 2005 | 10:24 PM
Ferocity02's Avatar
Very nice! Is that a 347 or did you go bigger? Keep us updated!
Old Jun 2, 2005 | 05:51 AM
smokinHawk's Avatar
nice merge.
Old Jun 2, 2005 | 09:10 AM
sb427f-car's Avatar
SSU'S Vice Mod
Originally Posted by smokinHawk
nice merge.
Yeah! This is going into that chevelle I take it? That sucker should move quite nicely. What's going to back it?
Old Jun 2, 2005 | 10:27 AM
I built did a 347" setup, 8:1 compression. From my last setup I have a t400 with a brake. I tightened the stall from 5000 to 4000 rpm, and I swapped the 12 bolt gears from 4.11 to 3.42 for the top end charges at 150+ mph with my 26" tall 315/35/17 drag radials.
The motor went in pretty easy, I just had to notch the pan and fab the mounts. I also lowered the motor and slid it back about an inch.
The merge collectors are just like the burns, I cant see spending $1000 when they are easily built for less then $200 in materials. Plus I desined them a little shorter for space limitations.
In the next week or so I will have some pics of the motor with the headers and turbos on.
This entire project was really cheap actually. I did a lot of wheeling and dealing for parts, and I get discounts. All I have left to buy when the time comes is the cold side plumbing, Flashscan, and an LC-1 wideband. Then it's dyno time.
I can't wait to have it done, I want to start enjoying the summer with my family and not be couped up in the garage!!
Old Jun 2, 2005 | 11:38 AM
Got Me SOM's Avatar
are your valvecovers anodized? Think you just gave me and idea..
Old Jun 2, 2005 | 11:44 AM
For the valvecovers, I removed the coil mounts, filled the 2 grooves down the center, welded the holes that were for the vents and coil mounts, and painted them gloss black.
Old Jun 2, 2005 | 01:19 PM
Got Me SOM's Avatar
I used to own a 70
Chevelle SS 396 a turbo 400, 12 bolt rear, I miss that car.
 Michael S. Palmer
