What are your dimensions for FMIC
After going through all of my logged 1/4 mile track runs. It looks like the OBX FMIC is doing a great job on IATs for me. With 6lbs of boost my average IAT temp is only 18 degrees above ambient. At peak which was after back to back runs (hot lapped) at the track the temp was 25 degrees above ambient. The IC was still very cool to the touch when returning to the pits. I expect this to go up when I put the new 3.7 pulley on this week, as I'm hoping to see around 9-10lbs of boost.
if the problem is known on the OBX, and a solution to that problem can be done to increase performance from that unit, then why has not any one done it?
all i see is cutting off one of the tanks, turning it over, and welding it back up so the inlet is not matched up to the exit forcing the air to run a zig zag so to speak.
My concern is weight and the construction. While the cooler I have looks fine its possible there were some others that have fallen apart. It works OK on my car but I cant say if it does or doesnt work as well as a spearco, griffin, bell, etc would. If someone wants to send me another 'better' unt with the same or close dimensions as the OBX I will be more then happy to try it - if it works measurably better I'll buy it, if not I'll send it back
Like I said before, and I know all the OBX owners are probably wondering deep down.... If you buy the best in this case you will never have to wonder how much power might be gained buy a top of the line intercooler. I justified it this way, How many times have I done a mod only to try to tweak even more out of it??? If you are losing power from a cheap intercooler, you can never gain that back unless you change it.
For me it was a bigger deal because of my goals on pumpgas. I need EVERYTHING to be as efficient as possible. If not, I will not reach my goal. I know I didn't spend big money, Weeks of labor, and tons of research(just like most people), Only to buy some unknown inneficient part that could cost me power. Besides, at this level of the game, what's an extra $500??? Really!
I wish I could see a comparison between all the big name intercooler companies for flow, pressure drop, and cooling. They would all have to be the same size and thickness. Then we would all know for sure. But for now, I will have to go off what I have been told and what the biggest names in racing use.
I have the TA unit (while I wait for the rest of my parts) and it looks perfect.
I have no doubt the OBX will work fine, though.
Rich
I may try a griffin down the road but I have other things that are more priority at the moment. Being such a small difference in price (I had thought the griffin was like 800.00) if I was starting from scratch I would probably use the griffin just for the weight savings and being USA made.
I just bought a OBX and I plan to use on my fi project. I can understand the need to support sponsors, I usually do. But in the case I couldnt justify the extra money.
Like I said before.. Id like to see some comparos. Ive seen a few posts about OBXs being logged and IATs seem impressive. I see a lot of people barking about the OBX is cheap.. and you get what you pay for... but no one has any real proof.
Anyone have any comparable Spearcos or Griffins logged? I honestly would like to see them.
Now,for OBX I've had very good experience with them up to 14lbs of boost.A back to back to ATI showed the OBX gaining 2lbs of boost - 8lbs to 10lbs and the inlet temp dropped 70 degree's.The rest of the cars were Turbo so it is harder to compare.On a 50 degree day we ran a car at 14lbs through all 4 gears and the highest inlet temp was 80 degree's
That was on a 700rwhp car.A recent truck running a 4.8 and 15lbs got up to 90 degree's from 0-100mph on a 75 degree day.So the OBX does a good job for how much it is,maybe even better than alot of people think.Now,even I'm thinking which intercooler to run for a 1000hp setup
ps...gonna be while though
