What plugs for 15-18 psi?
Old Jun 3, 2005 | 12:08 PM
nitrorocket's Avatar
Default What plugs for 15-18 psi?
I have searched, found nothing in this range. I am looking for about 15 to 18 psi of boost and am wondering what experience with plugs you've had. I am only running 92 octane. Some say NGK TR6, but I think one colder would be better. Is there a TR7, I haven't seen one. Anyone have a number for it?
Old Jun 3, 2005 | 02:31 PM
boosted99camaro's Avatar
dont know about the tr7 but tr6s seem to be the norm with fi and spray.
Old Jun 3, 2005 | 02:41 PM
narcszm's Avatar
it's called NGK BP7EFS. I have a brand new set if you wanna try them
Old Jun 3, 2005 | 03:00 PM
badbilly's Avatar
anyone using densos?
Old Jun 3, 2005 | 03:07 PM
Big Rick's Avatar
NGK R5724-8 NExt coldest plug after the TR6
Old Jun 3, 2005 | 03:23 PM
narcszm's Avatar
not true, rick. The dash eight is two steps cooler than the TR6.
https://ls1tech.com/forums/showthread.php?p=2089592
Old Jun 3, 2005 | 03:49 PM
y2khawk's Avatar
I have used TR6's as well as the quote unquote 7's. Ran 6's in the high teen to low 20 psi range. Switched to the 8's for a short time, but they fouled to easily for my taste and the 7's held up quite well. Ran those plugs anywhere from 24psi up to 30 psi last year.
running 6's in the truck at 10 to 12 psi, FWIW
Old Jun 3, 2005 | 03:59 PM
parish8's Avatar
single digit dreamer
i have ran up to 18psi so far on tr6's, i tried the tr7(br7ef) and didn't like the way they ran.
to go from stock to tr6 you can just barely tell they are in there, just a slighly worse idle. then goto the tr7's and it had an audiable miss at idle and felt much rougher. i have tried 2 sets of the 7's and they both ran the same so i went back to the tr6's. i figure i will step up to a colder plug when i show an actual need to step up.
Old Jun 3, 2005 | 04:03 PM
narcszm's Avatar
yeah the LS1 heads dissipate heat well enough that you'll never need anything cooler than a 7-range. dash eights and nines are from some OHC motors and oil/air cooled motors like vee-dubs and porsches where the head runs much hotter.
Old Jun 3, 2005 | 04:11 PM
I doubt I will ever be over 20 psi on pumpgas, But I was worried about a TR6 leading me to detonate at that level on pumpgas. BUT, sounds like a TR6 wouldn't be a bad place to start. I guess I will reconsider a TR6.
Old Sep 5, 2005 | 10:58 AM
Shinobi'sZ's Avatar
Did you keep the factory gap of .039 or did you gap them down. I have the TR7 IXs and am getting a little back fire (occasionally) at idle and when off throttle cruising.
Old Sep 5, 2005 | 11:12 AM
Race Car Driver's Avatar
11 & 7 Second Clubs
Don't take a poll. Ask Kurt at W2W.
Old Sep 5, 2005 | 11:42 AM
MIGHTYMOUSE's Avatar
i bounce between a tr-6 and an autolite ar 3911 (per w2w)
i think the 3911 is a little colder than the tr6 but i havent noticed a difference in performance at mid teens boost.
Old Sep 5, 2005 | 01:55 PM
Shinobi'sZ's Avatar
What do you run the gap at on the TR6s? You still using stock plug wires.
Old Sep 5, 2005 | 02:09 PM
spun03cobra's Avatar
Well I'm going to be running 15+ psi and on my N20 on my turbo set up. Before I ran just 300hp of spray and ran a auto lite Ar93, the straps are cut back and have a factory(auto lite) gap setting of .026. I would say the ngk's are a little more forgiving than the autolite as the ngk will melt the strap at a lower temp to save the cylinder unlike the auto lite. As for the my N20 set up on my car I never hurt a plug and that was on a stock short block and heads.
You can call the auto lite tech line, give them your application and they will give you a plug.
Old Sep 5, 2005 | 02:50 PM
i run tr6's at what they are pre gapped at which is around .035, yes stock plug wires.
Old Sep 5, 2005 | 10:29 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm running TR8's, MSD wires, and never have any ignition/missing problems.
Old Sep 6, 2005 | 10:02 AM
ESR's Avatar
ESR
LS1TECH Sponsor
Default denso iridiums
I used the denso ir. at one point can remember the initials before the number but the were the -22s the equivalent to a tr6 I believe the gave the car a nice idle quality.......but I was having misfire problems and switched to tr6. It ended up not being the plugs but I was too lazy to put the densos back in they had a good cold start(densos). They are way too expensive though.
