Help ???
Old Jun 3, 2005 | 12:43 PM
moto-mafia's Avatar
Default Help ???
Hey guys i have a 99 trans am , it has a procharger on i t, recantly i let it run a little low on gas and since then the car stutters and falls flat on its face . ... also it wont build past 5 psi ..... i was thinking it was a fuel filter problem ?? wanted t o know if any one else has any simular prob??? maby vacum leak???
Old Jun 3, 2005 | 12:52 PM
NOSjohn's Avatar
Restricted User
If I'm correct in what you're saying, you were getting on your car hard and it ran out of gas ? Since that point in time, the car will now stutter anytime you get on it under boost or other? Your statement is kinda sketchy, try to explain a little better please.
Old Jun 3, 2005 | 01:04 PM
moto-mafia's Avatar
no i was driving like normal and ran REALLY low on gas not out but pretty damn low , since then the car stutters like hell and runs like total **** , ,, , , ok some of the time the longer you drive the worst it gets
Old Jun 3, 2005 | 01:15 PM
NOSjohn's Avatar
Restricted User
If you have the capability, check your fuel pressure at the rail and see what it is. If not, just give your car a tune-up, it may be time.
