crank??
John
Keying the crank would keep the pully from spinning on the crank. This would require me to remove my crank and have a keyway milled into the snout. Which i dont want to do if I dont have to. Will pinning The snout be enuff or will drilling the holes weaken the crank.
Less vibration. The stock crank is strong enough to pin twice at 180 degrees apart with no problems, many have done it for years, be carefull to not drill too deep, when pinning. The horizontal pin kit i bought might have been from Tbyrne i cant remember??
