Speed Inc. 348 Short Block
Old Jun 8, 2005 | 01:13 PM
YOUR03COBRA8ME's Avatar
Default Speed Inc. 348 Short Block?
What do you guys think of this set up it seems reasonable
I want around 600hp boost like 15psi but i want it on the safe side
Old Jun 8, 2005 | 02:18 PM
LSs1Power's Avatar
15psi in a 348 LS1 should put u over 700rwhp with the right Turbo. If u just want 600rwhp then 10-11psi should do it with the right Turbo.
Old Jun 8, 2005 | 02:35 PM
As far as this motor goes good bad or other
Old Jun 8, 2005 | 02:37 PM
BOOSTNSS's Avatar
forged bottom end should be no prob for 600rwhp a stock crank is all that is needed too
Old Jun 8, 2005 | 02:55 PM
Wicked_Hugger99's Avatar
motor should be just fine
You should hit ur goal fairly easy
Old Jun 8, 2005 | 03:12 PM
SUPER DAVES Z's Avatar
You should have no problems with a short block built by them, especially with only 600 rwhp. They do quality work. I think they have one of their 348's putting 840+ rwhp with one of their turbo kits. (reference wicked's car!! )
Old Jun 8, 2005 | 03:16 PM
ddnspider's Avatar
im getting a very similar setup...are you sure about that 700rwhp number?i was looking for 15psi as well(which both miine and You03cobra will handle) but that seems like a high number with just 15psi.
Old Jun 8, 2005 | 03:17 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have a 8.2:1 Speed Inc. Shortblock making 754rwhp thru a T400.
Old Jun 8, 2005 | 03:20 PM
ddnspider's Avatar
at what psi?my CR is gonna be about 9:1 which is where the Spped Inc SB is at i believe.not meaning to steal the thread but we're basically in the same situation
Old Jun 8, 2005 | 03:23 PM
HellRaiser's Avatar
Don't forget these are V8's. When people think of a boosted car's they think of the 4 & 6 bangers that need like 20+psi to make big power.
Old Jun 8, 2005 | 03:25 PM
LS1Tech Co-Founder
21 psi, t400, blower, and my cam was not picked for peak hp. I made 735rwhp with 17psi and a different cam, but it was peakier.
Old Jun 8, 2005 | 03:27 PM
ddnspider's Avatar
very true.im just curious what sort of numbers to expect with say 12-15 psi.i KNOW im going to run out of turbo with the T67 that came with my Phamspeed kit.i was told by the sponsor building my motor that im good for anything under 20psi or 1000rwhp,whichever comes first which is always good to know
Old Jun 8, 2005 | 04:05 PM
LS1Tech Co-Founder
Depends on your cam size, how well your heads flow, and the size of the turbo.
Old Jun 8, 2005 | 05:12 PM
LSs1Power's Avatar
Maybe 15psi with a T76 will do 700rwhp, but i dont know about the T67. Why dont u just get a larger turbo and call it a day
Old Jun 8, 2005 | 07:29 PM
ddnspider's Avatar
cause i just changed my mind and am going with custom pistons and a 383
Old Jun 8, 2005 | 09:17 PM
SINISTER's Avatar
i will stand behind anythin speed inc puts togeter.. contact them great customer service
Old Jun 9, 2005 | 06:26 AM
sweet good deal guys thats for the info
Old Jun 30, 2005 | 11:04 PM
Jimmy P's Avatar
Who builds their motors?
