Why is this such a slug without the spray?
Old Jun 8, 2005 | 07:26 PM
860 Performance's Avatar
Default Why is this such a slug without the spray?
Heres what I have:
Small Block Chevy (not an LS1)
Accel DFI, Novi2000 producing 11psi. Intercooled, TPIS Miniram(which I'm not too fond of), Dart II Iron Heads 2.02/160 valves, headers, into 2.5" duals. 8:1 compression, oringed block, splayed caps, good crank and rods
Cam specs: roller hydraulic 236/248 @.050 113LSA, .586"/.562" lift
Went to the dyno yesterday, and this set-up only put down 365rwhp? The a/f was right around 12:1 the entire pull. I only run pump gas, and total timing at max boost was set at 22deg.
Why is this so slow?
Am I being too conservative on my timing map?
Then I spray it with a 300 shot which brought it up to 663rwhp, which is good, but I expected bigger numbers from the blower.
Old Jun 8, 2005 | 08:29 PM
lcvette's Avatar
8:1 compression is a little on the low side.. up the boost some!
Chris
Old Jun 8, 2005 | 10:44 PM
conan's Avatar
Your cam might be a problem too. With the higher intake lift than exhaust and the 113 LSA
Old Jun 8, 2005 | 10:48 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I"m 8:1. I run a 590/600 lift cam.
I think the issue is somewhere in the combo. You should hit 350rhwp+ just on motor.
Old Jun 8, 2005 | 11:14 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
The only reason to drop c/r down to 8to 1 is to run way more than 11#'s of boost. If you stay at 11, however, I think your timing is a few degrees low.
Old Jun 8, 2005 | 11:19 PM
LS1Tech Co-Founder
Difference 'tween 9:1 and 8:1 is that the latter will need to make 1 more lb of boost to make the same power.
Old Jun 8, 2005 | 11:43 PM
Wnts2Go10O's Avatar
higher boost, different cam, and different intake. get a holley stealth ram manifold and transfer all the stuff from the miniram to it.
Old Jun 8, 2005 | 11:46 PM
narcszm's Avatar
you cam overlap is huge. Get a grind with smaller duration and a LSA no less than 115 and you should see another 50HP off the juice.
Old Jun 9, 2005 | 01:49 AM
KissMySSo1's Avatar
You've got to remember there's a 700R4 behind it which isn't helping much. Also what is the overlap between the valves on the cam. Is it in the negatives? If not you could be blowing the boost right out the exaust valve. Get rid of the miniram quick. Another thing. Were is the peak power? Are your valve springs weak? Also check your mechanical aspect of your timing. If somthing is off, the DFI could read 22* of timing but the motor could see none or even negatives. If it's none of that then all i can say is jump on the roof.
Old Jun 9, 2005 | 03:40 AM
Nate_Taufer's Avatar
Well since you're running 16 degrees of overlap i would say that could be a huge problem right there. Check all charge piping and make sure you're actually seeing 11 lbs. Then do a compression check.
Nate
Old Jun 9, 2005 | 05:50 AM
Slowhawk's Avatar
LS1Tech Sponsor
Your boost/timing is real low for your Combo.
Let me know if you need some dyno time and we'll make sure you get a torque readout/A/F
Old Jun 9, 2005 | 08:22 AM
Wow, thanks for everyones help so far!
The compression is good, its a fresh motor.
The actuall timing is matched to the DFI.
Valve springs are stong as hell because of the wet shot.
The cam is really a nitrous cam.
I guess that it cam+ miniram is the biggest problem.
I'll do some more tuning, and probably leave it for this season, since i just got it together. It still hauls on the spray, so when I need to put it down I can.
Slowhawk, I've been looking for a reason to get down there, this might be a good time.
Old Jun 9, 2005 | 01:59 PM
MrDude_1's Avatar
theres nothing wrong with the miniram....welll as long as you get one of the ones thats not porus... and it machined right so it seals properly... lol.
biggest problem i see is a bit of a mismatch.
CR is setup for big boost... but you arnt running big boost so its hurting you.
the cam is NOT forced induction friendly... jumping to a smaller cam in this case would give you a power increase.. valve overlap is BAD in forced induction motors.
Old Jun 9, 2005 | 03:22 PM
narcszm's Avatar
I bet if you calculated your dynamic compression ratio with that cam, you'd be somewhere around 6.5:1. Your dynamic boost compression ratio, then, might be as high as 11:1. Long story short, as most everyone has pointed out, it's just your cam that's killing your power.
Old Jun 9, 2005 | 04:05 PM
mongse's Avatar
I ruin the end of films...
More lift. My old blower cam was 236/242, .600/.612 @ 114 and that was a small Procharger w/ a 100-hit.
I don't see a problem w/ 8:1 compression on iron heads. Aluminum heads, yes, that's a bit low, but not too bad w/ irons.
Old Jun 9, 2005 | 04:30 PM
LS1Tech Co-Founder
I disagree with most of you, except for the boost part.
I run 236/246//114//590/600 cam, makes 754rwhp at 6600 thru unlocked T400, with 21 psi. I make over 700rwhp by 5000 rpms and my average hp is over 700rwhp. My cam was originally going to be 236/242 from Terry but I asked for more exhaust duration.
Sure you are not getting crazy belt slippage or something?
I'd be running 15psi at least with that compression.
Old Jun 9, 2005 | 08:14 PM
Wow, thoes are some serious numbers with a kinda-similar cam....huh
Well, its easy enough to increase boost. I'm not getting belt slip, but it has a monster pulley on the blower, so thats why its only producing 11 psi. I had called paxton directly before about getting a smaller pulley, but they couldn't help me because its a custom set-up.
Anybody reccomened a place who could set me up with a pulley for the Novi?
Old Jun 9, 2005 | 10:42 PM
LS1Tech Co-Founder
Can you use Mustang blower pulleys? if so try the Mustang sites.
If not, perhaps talk to Lee @ ASP.
Something does not make sense with your combo, I'd expect you to be over 550rwhp.
Is your converter really loose or your trans messed up?
Old Jun 9, 2005 | 10:58 PM
RealQuick's Avatar
Are you verifying boost with a gauge in the intake tract or are you quoting 11psi by the pulley ratio?
Old Jun 9, 2005 | 11:12 PM
LS1Tech Co-Founder
On just blower does the power just flatline at some rpm, like 5000 or something? That could be big belt slippage.
