Where to find an MMS crank pulley?
Old Jun 12, 2005 | 08:36 PM
00SSQuiniqua's Avatar
Default Where to find an MMS crank pulley?
Just as the title describes, I have a procharger setup and the SDCE setup is a little out of my price range as of now so I'm looking for the cheaper solution. If anyone has an idea where I can find one of these I would appreciate it because from what I understand they went out of business or no longer make them. Thanks
Old Jun 12, 2005 | 09:02 PM
kp's Avatar
kp
By the time you find one and buy a couple blower pullies and belts you will be much better off with the SDCE. SDCE sells a 6rib upgrade that is cheaper then the 8 rib, I dont pimp a lot of things but like a lot of others here I have tried the MMS and it does work for a while if you tighten the crap out of the belt. If you do that you will be going through idler pulleys like crazy. I have not one complaint about the SDCE so far.
Old Jun 12, 2005 | 09:11 PM
frcefed98's Avatar
MMS is good and all but belt life is also crappy too, since you have to tighten the **** out em for best results.
SDCE is the one you should go with, take it from someone that went through this already....MMS, ASP COGs, Various ATI pulleys, and finally the SDCE set up.
I didn't even mention the cost in belts alone.
J
Old Jun 12, 2005 | 10:27 PM
I appreciate the input guys. I've kept up with alot of the forced induction threads and have learned who really knows there stuff and I know I cant argue with kp and frcfed. I guess I'll have to save up for the SDCE.
Old Jun 12, 2005 | 10:34 PM
liftin'em on nittos's Avatar
anyone have a link or some info to the SDCE setup? i'm just starting to get into the blower setup for my fbody (former mustang guy) and i need some info on the "best" parts. damn, frcefed...running a 102 on a 348...that's gonna make some sick power...
Old Jun 12, 2005 | 10:37 PM
Ed Blown Vert's Avatar
I'll be selling mine when I get the SDCE setup.
Old Jun 12, 2005 | 10:51 PM
What was your experience with the MMS crank pulley?
Old Jun 12, 2005 | 11:02 PM
frcefed98's Avatar
here is a link to sdce site
http://www.sd-concepts.com
PM SDCE here on the board for prices and direct info. Wendy is great and scott will talk your ear off on why his set up is the best, I bought it and was glad I did.
KP has my old set up Glad its working awesome for him, like it was for me
Liftinem' I wish it was a 102, but it specs out to be a 74mm or close to a 76 from what I've read here. Next step up will be a T-88 for me. I'm new to turbos and their terminology so I'll just say I have a pretty big turbo on it for now
J
Old Jun 12, 2005 | 11:11 PM
ok, i read it wrong...my bad. i was thinking a 102 was pretty HUGE for a ~stock cube LS1 car but it would be cool for sure. good luck with it turbos are fun
