need to order part quick. but where?
Old Jun 15, 2005 | 12:34 PM
StoleIt's Avatar
NKAWTG...N
Default need to order part quick. but where?
okay for the return oil line from the turbo on a TTi street kit, this 90 degree bend with a barb was provided. I tapped the pan but now the thread i used on the tap (18) doesn't match up with this provided peice. I Need to order a new one with the proper thread, anyone know where I can get this? the peice is 5/8 on both ends. this one provided is more like 20 or 22 threads per inch, i need an 18. the tap i used is out of my friends standard plumbing set. ive been to the local plumbing places and to every regular hardware store in a 30 mile circle. PLEASE!!!!! internet web sites with fast shipping welcome.
Old Jun 15, 2005 | 01:02 PM
NOSjohn's Avatar
Restricted User
Try a Hydraulic Supply company or a truck and tractor place. I know you guys have farms out there, I've been in that area. More than likely the easiest answer will probably be just going to a bigger fitting with std. thread sizing and re-tapping the hole. Stop doing stuff the quick way like using a buddy's Plumbers tools! Take your time with the install...it will come.
EDIT add: NPT (National Pipe Thread)
Jegs also has AN to NPT fittings... check them out.
Googled this:
http://www.spmed.com/SPresults2.asp?...AND%20ADAPTORS
Old Jun 15, 2005 | 01:51 PM
StoleIt's Avatar
NKAWTG...N
whats weird is one of the other fittings for my relocated power steering lines fits on this new 5/8's thread like a glove. only problem is its for power steering and isnt a 90 bend. so that lead me to believe their is a chance i can find something to work.
Old Jun 15, 2005 | 04:10 PM
NOSjohn's Avatar
Restricted User
Problem solved, I called a place that gets fittings for airplanes...even Mil-spec. stuff.
