.581 cam with STS Questions.
Where would the powerband be with an 8.5-9 to 1 compression engine? And is this going to be a decent cam for this setup?
Headers do not add as much on turbo applications, especially the rear mount models. A friend and I put the STS kits on and dynoed at the same time ( he LT headers, me stock ). The power difference was about 6 whp, unlike N/A where he had me by 30+ whp. I would use the money to ceramic coat the stock manifolds and Y-pipe, else a turbo upgrade.
-Bryan
Comp Cams XE-R 224/224, .581/.581 112 LSA
Part #: 54-000-11
Grind #: LS1 3722R/3722R HR112 LS1 Speed
Serial #: C 7622
Int. Exh.
Valve Adjustment HYD HYD
Gross valve lift .581 .581
Duration @
.006" Tappet Lift 273 273
Valve Timing Open Close
@ .050" Int. 0 BTDC 44 ABDC
Exh 44 BBDC 0 ATDC
These specs are for cam installed @ 112 intake
center line
Int. Exh.
Duration @ .050 224 224
Lobe Lift .3420 .3420
Lobe Separation 112.0
Who makes an "off the shelf" cam made for stock cube with turbo and decent to fair idle? I like just a hint of a lope but no surging while cruising, M6.
I do know from experience.
Speed inc sells a nice turbo cam.
225/225 @.50
273/273 adv. duration
.581/.581 lift
113LSA
overlap is -1
