383 Stroker - Cam & Injectors
Old Jun 21, 2005 | 11:37 AM
ddnspider's Avatar
nope,i WAS going to use the 1 in my car already...LPE GT2-3 but ive decided to just build this motor totally and sell my whole longblock in my car now.so im thinking about the sleeper2 cam from MTI,i like it and it sounds great and would sound even more quiet since itll be in a 383 and not a 346...ie same cam in bigger motor acts smaller.
Old Jun 21, 2005 | 11:38 AM
ddnspider's Avatar
MTI Stealth Series
Cam Duration Lift Lobe
Separation
Intake Exhaust Intake Exhaust
Stealth I 220 220 .581 .581 115
Stealth II 224 220 .581 .581 116
Old Jun 21, 2005 | 11:42 AM
Ed Blown Vert's Avatar
Yep, you are doing what I am doing. I am using all new parts for the engine.
Old Jun 21, 2005 | 11:43 AM
MTI Stealth Series
Separation
I like the lift, why the reverse splt?? I think I would want more duration, but what do I know.
Old Jun 21, 2005 | 01:40 PM
ddnspider's Avatar
because i have a phamspeed kit and am using the stock headers from an 02 car so i dont have as much of a free flowing exhaust setup as possible,but my intake is great,my FMIC has a .2 psi pressure drop at 15#s.also the more intake will help me have less reversion.
Old Jun 21, 2005 | 01:46 PM
I forgot, your turbo. :sillyme:
Old Jun 21, 2005 | 03:00 PM
ddnspider's Avatar
YUP!so i figure with a better intake setup than an exhaust im better off with either no split or a reverse split...SO i cant decide between the 2 sleeper cams..im leaning towards the sleeper2 cam cause of the tad higher LSA and itll help stop any reversion.
Old Jun 22, 2005 | 05:35 PM
Originally Posted by Got Me SOM
its pushing it, i lean more towards no than yes.
Hmm... I could always go with a 115 if that would help.
 Michael S. Palmer
Old Jun 23, 2005 | 11:53 AM
ddnspider's Avatar
i just sent out the T67 that came with my turbo kit.....and when i get a package back its got a T76GTS in it cant wait!
Old Jun 26, 2005 | 10:49 AM
I am guessing that is bigger
Old Jun 26, 2005 | 11:50 AM
ddnspider's Avatar
much!
Old Jul 1, 2005 | 12:33 AM
  #32
One last bump.
Old Jul 4, 2005 | 12:07 PM
  #33
sb427f-car's Avatar
SSU'S Vice Mod
Ok, I have a question about this myself. The car that I've been working on, the way the deal is structured I'm waiting on the seller to sell his 408 (geared for NA / N2O) as it wasn't what I wanted and he had had a side deal to sell it. At any rate. I've found a short block that I'm considering and would be toping it off with most likely a thin or stock gasket and a set of LQ4/9 heads for now. It's a 382, 4" stroke, and it would most likely breath through a set of stock manifolds till next year. At that point it's going turbo with either a set of 1 5/8 primaries or 1 3/4s. So, he's the question. I'm not worried about maximizing the 382 NA, as long as it has some decent power (slightly more than stock) but would be best geared for a change of head gasket, some port work, and be setup to go at this forced induction thing end of next year beginning of 07. Basically I'm in the same boat as Ed, and was curious what bump stick would probably work best, with basically the same requirements that he has, slight lope, emmissions acceptable, streetable, doesn't kill idle or fuelmileage THAT bad (obviously gonna give up some). Definately wanna keep the LSA >=114
Old Jul 4, 2005 | 12:39 PM
  #34
ddnspider's Avatar
look at the boosted lists that are stickies and see what some of them use as a cam with their s/c er.what most people are listing will work ok,or give a few companies like Futral Comp and Forced Inductions a call to help you decide.
Old Jul 4, 2005 | 01:06 PM
  #35
sb427f-car's Avatar
SSU'S Vice Mod
Yeah, I might do that if I decide to go this route ddn...thanks. Oh, btw, the boosted list is down as boostaholic can't host any more.
Old Jul 4, 2005 | 01:47 PM
  #36
ddnspider's Avatar
i just looked at the 2003 list just this second.i believe its the 05 list that we cant view.
Old Jul 4, 2005 | 02:02 PM
  #37
sb427f-car's Avatar
SSU'S Vice Mod
Ah that would be correct.
Old Jul 4, 2005 | 02:27 PM
  #38
ddnspider's Avatar
so you can still get an idea from the 03/04 lists.personally im looking for something like a 230/228 .58X/.58X 116 for my turbo 383
