Turbo Fabbing...
Old Jun 22, 2005 | 10:58 PM
blazin's Avatar
Default Turbo Fabbing...
Well here is a setup im thinking about fabbing up on my car. Im going to pretty much clone the ptk with the exception of the headers. I want to use a set of shorties that are 1 5/8 in primarys(are they large enough?). The plan is off the passenger side header run a cross over to the driversside, dump the drivers side into the crossover where it will run into the turbo mounted by the radiator. The question is will these headers flow enough air? Then routing the down pipe back to the car is another challenge. Im assuming that most kits run the down pipe under the k member of the car?
Well here is a pic i drew up in like 5 secs lol. Any input would be nice.
Thanks.
http://domestic-street-scenes.com/blazin/tbsetup.jpg
This is a lt1 car btw.
Old Jun 23, 2005 | 02:10 PM
ddnspider's Avatar
looks exactly like the Phamspeed kit....yes they'll work...theres people making 1000rwhp+ on truck headers.but stock headers will work fine,but yes thats the basic drawing of what it would look like,and they run under the K member
Old Jun 23, 2005 | 02:37 PM
RealQuick's Avatar
Like I mentioned on cz28, If you try and route the DP over the k-member on the driver’s side, you’ll probably run out of room. This will probably force you to run the DP under the k-member like the phamspeed kit.
Old Jun 23, 2005 | 03:16 PM
ddnspider's Avatar
thats sounds about right!
Old Jun 23, 2005 | 04:12 PM
blazin's Avatar
Ya I wonder how much ground clearence i will lose. I will just have to figure something out I guess. Im glad to hear the pacesetter shorties will work so i dont have to hack up high dollar headers.
Real quick wonder if they would ler me order two pass side headers lol.
Old Jun 23, 2005 | 04:32 PM
MIGHTYMOUSE's Avatar
have you looked at rice etr's home build? its probably the best layout ive seen.. though i could certainly do it much better skill just holding me back
http://www.fastrides.com/photos/rice_etr/default.aspx
Old Jun 23, 2005 | 05:04 PM
blazin's Avatar
Here are some things that I added up.
Check it out and let me know if im missing any crutial parts and peices, or know of better prices.
PT67 Turbo $1395
Tial 44MM V Band Wastegate $369
Tial Wastegate Flange $18.00
Tial BOV 215.00
Tial BOV Flange 20.00
T-Bolt Clamps 10= 50.00
Turbo Flange= 25.00
5 J bends 50.00
Front Mount Intercooler 200.00
Misc **** 200.00
What size of intercooler do I need for a front mount.
Old Jun 23, 2005 | 06:09 PM
Z06PSI's Avatar
You can get the PT67 a little cheaper if you look.. I just bought a brand new PT-88 for 1400.00
Old Jun 23, 2005 | 08:01 PM
1moreblackta's Avatar
i thought intercoolers were alittle more expensive
Old Jun 23, 2005 | 09:41 PM
Z06PSI's Avatar
OBX = 300.00
The Misc **** is way too low. More like 1k
Old Jun 23, 2005 | 10:01 PM
ddnspider's Avatar
FMIC is 300 like said...NO WAY IN HELL that turbo is 1400....its $1K ON WWW. FORCED INDUCTIONS .COM...and add a zero to your misc section
Old Jun 23, 2005 | 10:07 PM
blazin's Avatar
PT67 790hp T04H T04 / GTQ-trim $1395
Is the GTQ trim the new garret design that is suppose to spool quick?
Ya what size of intercooler should I get?
the misc **** my cost more and more but we will wait till i get the kit fabbed up and see what all esle is needed.
What happened to all the OBX on ebay?
Old Jun 23, 2005 | 10:10 PM
ddnspider's Avatar
straight from their website
PT67GTQ
790
OC. .69, .85
Tang. .58, .68, .81, .96
$1025
Old Jun 23, 2005 | 10:12 PM
blazin's Avatar
*PTE prices have changed as of Feb. 28th. Call for new pricing**
Maybe they went up dunno if its cheap through jose ill order from him.
ddnspider's Avatar
they'll be back,look for a company called XO2RACING.i went with a 24X12X3 which seemed small in my mind til i got it...itll be plenty big to do the job...ie 600+rwhp
Old Jun 24, 2005 | 07:41 AM
RealQuick's Avatar
PT67 Turbo $1395
Tial BOV 215.00
Turbo Flange= 25.00
5 J bends 50.00
Misc **** 200.00
Do you have the headers already? If not *** that in... You can buy that turbo of turbosmustangs or tubobuicks much cheaper if your willing to buy used. I bought a PTE76 Q trim with less than 1000miles on it for $950 and just picked a PTE74 Q trim for my boss' 67 camaro for $825 (fresh rebuild 15 quarter mile passes ago).
I dont know if SLP will let you order to pass. header. I would call and ask. I bought mine from a cz28 board member.
