Help With Turbo Build
Old Jun 26, 2005 | 01:51 PM
jaredwayt's Avatar
Default Help With Turbo Build
whats up guys, im in the process of putting togther a turbo kit, and i had a
few ?'s.
-what turbo kit would you reccomend for about 10 psi for a stock bottom end being safe, maybe a t-76?which brand?
-@10 psi on stock bottom and and stock heads,with a custom turbo cam and all supporting boltons and fuel system, how much power would i be looking at through a 3.42 and a 10 bolt-m6?
Old Jun 26, 2005 | 01:58 PM
ddnspider's Avatar
give Jose a call or shoot him a pm...go to www.forcedinductions.com he'll help you reach your goals,and to break 500rwhp all you need is like a t67 turbo but
id see you breaking 500rwhp if you have everything setup right.
Old Jun 26, 2005 | 04:16 PM
FastKat's Avatar
Don't worry about a special cam... the stock LS1 cam should work find if you're sticking within the output range a stock bottom end can reliably produce.
few ?'s.
Old Jun 26, 2005 | 06:13 PM
jaredwayt's Avatar
i was looking at the phamspeed kit, with a t076 up grade, w/ a fmic, do you think at 10psi, with the right boltons, and fuel system 500rwhp is possible?
Old Jun 26, 2005 | 06:20 PM
ddnspider's Avatar
you'll make that easily!ive got a Phamspeed kit,do a search for Phamspeed dyno numbers cause a member called 99SS-T i believe posted some numbers the other day,make something like 540rwhp at 10psi i think.
