Forced Induction Stuff 4 Sale
#1 F-1 Procharger, Steel J-bracket, SDCE 8 Rib spring loaded tensioner,ATI crankshft damper,inlet hat,mounting studs and spacers.=$4200(all is new and never ran more than 10 min)
#2 FMIC(900 hp),3 inch aluminum piping,t-bolt clamps,silicone hose couplers,silicone transition hose(3 to 3.5 and 3 to 4),ATI Race bypass valve,IAT sensor mounted in 3 inch pipe. This is a complete set up from the supercharger to the throttlebody(everything needed)=$900(all is new and never ran more than 10 min)
#3 Rossler 400 turbo with trans brake, midwest 3500 stall torque convertor,gear-venders overdrive unit, steel driveshaft,tranny cooler and lines,factory shifter reworked by Mike Brown to work with the reverse shift pattern in the 400 turbo.= $3800(very low miles)
#4 9 inch moser rear end(35 spline with a spool) with Spohn drag sway bar= $2200
#5 Shortblock=5.3 iron block- bored 125k over to a 3.910 bore-forged pistons-billet rods-stock crank-Comp R lifters-cam for supercharger,C5R timing chain(built by Reckless=Todd Brandon)
Heads= APE ported 6.0 heads,317 casting
For the longblock(no intake,oil pan,or front and rear covers)= $3500
#6 Two 28 X 10.5 X 15 W MT Drags(brand new, never mounted)=$350
#7 Set of Yellow Terra 1.7 ratio rocker arms(almost new)= $375
#8 Aeromotive A-1000 fuel pump(used very little)= $175
#9 Reichard Racing 3.5/6 rib supercharger pulley=$90
#10 Two 15 X 3.5 Weld Drag Lites with Moroso Drag Fronts(8ply),
Two 15 X 10 Weld Drag Lites with 26 X 10.5 X 15 MT Drags(tires have a few passes left)
Lug nuts,spacers, center caps= $600
#11 Kirkey Economy Drag Seat,aluminum,17.5 hip width,black snap on cover(Brand new, never mounted)= $125
All items are plus shipping
I'll have more stuff for sale, can't remember it all now.
Please email me if you have any questions, will have the stuff off the car this week and can take pics then if needed.
Tom
btw - i know all the neighbors love it!!! hahahahah
kevin
True that....
