Forced Induction Stuff 4 Sale
#1 F-1 Procharger, Steel J-bracket, SDCE 8 Rib spring loaded tensioner,ATI crankshft damper,inlet hat,mounting studs and spacers.=$4200(all is new and never ran more than 10 min)
#2 FMIC(900 hp),3 inch aluminum piping,t-bolt clamps,silicone hose couplers,silicone transition hose(3 to 3.5 and 3 to 4),ATI Race bypass valve,IAT sensor mounted in 3 inch pipe. This is a complete set up from the supercharger to the throttlebody(everything needed)=$900(all is new and never ran more than 10 min)
#3 Rossler 400 turbo with trans brake, midwest 3500 stall torque convertor,gear-venders overdrive unit, steel driveshaft,tranny cooler and lines,factory shifter reworked by Mike Brown to work with the reverse shift pattern in the 400 turbo.= $3800(very low miles)
#4 9 inch moser rear end(35 spline with a spool) with Spohn drag sway bar= $2200
#5 Shortblock=5.3 iron block- bored 125k over to a 3.910 bore-forged pistons-billet rods-stock crank-Comp R lifters-cam for supercharger,C5R timing chain(built by Reckless=Todd Brandon)
Heads= APE ported 6.0 heads,317 casting
For the longblock(no intake,oil pan,or front and rear covers)= $3500
#6 Two 28 X 10.5 X 15 W MT Drags(brand new, never mounted)=$350
#7 Set of Yellow Terra 1.7 ratio rocker arms(almost new)= $375
#8 Aeromotive A-1000 fuel pump(used very little)= $175
#9 Reichard Racing 3.5/6 rib supercharger pulley=$90
#10 Two 15 X 3.5 Weld Drag Lites with Moroso Drag Fronts(8ply),
Two 15 X 10 Weld Drag Lites with 26 X 10.5 X 15 MT Drags(tires have a few passes left)
Lug nuts,spacers, center caps= $600
#11 Kirkey Economy Drag Seat,aluminum,17.5 hip width,black snap on cover(Brand new, never mounted)= $125
All items are plus shipping
I'll have more stuff for sale, can't remember it all now.
Please email me if you have any questions, will have the stuff off the car this week and can take pics then if needed.
Tom
ill take your T400 with GV overdrive for $380, ill even throw in my T56.
just remind me to edit your post saying its forsale for $380
can i still talk you into staying FI.
good luck.
serious though can you seperate the sphoon drag swaybar from the 9", i have been wanting one of those.
Hawk, I hate doing it also, but the car has been done for over a month now and it still has yet to see the outside of the garage. The family is taking all my time, no time to have fun with the car anymore.
i bet if you took it for a spin youd have a harder time parting it.
come to think of it it will take more of your time parting it out then just enjoying it on occation.
so since your family is taking all of your time, you have no time to part it out, just use it to drive it back and forth to work
...hope you stay close to the scene...hasn't been the same without you! I completely understand the family issues....I'm there with you on that. Luckly I'm on the downhill side of those responsibilities.As Reckless stated...I also know Tom and will vouch for him.
Good luck with the sales, stay in touch!
Mark
I think I still have the parts list from ARE from when I ordered the parts.
do they have one for a th350 also?
sorry... but that is interesting...
tyler
tyler
ya think it can hook to a th350.
its an extra unit that can hook to the back of the transmission providing it with a high/low gear, so you turn a 3 speed into a 6speed, a 2 speed into a 4 speed.
I'm not selling the car, just want to get it back to where Mollie and the kids can enjoy it also.
Thanks
Tom
