exhaust temps
Old Jun 27, 2005 | 04:54 PM
mkoch1's Avatar
Default exhaust temps
I just installed a percy's exhuast gas temp probe in the number 7 cylindar, at idle fully warmed up it's showing approx 1300 degress. What are other people seeing. the probe is really close to the head. The header are coated,single turbo, stock internals. Wide band is not reading real lean, what's going on.
thanks
mark
Old Jun 27, 2005 | 06:00 PM
StoleIt's Avatar
NKAWTG...N
holy crap. i can honestly say that is about the 2nd craziest set up ive ever seen. first being that 8-turbo ls1 thing.
Old Jun 27, 2005 | 08:42 PM
Lostpatrolman's Avatar
:iagree: Interesting setup. Have any more pics of your car?
Old Jun 27, 2005 | 10:38 PM
mkoch1's Avatar
It's an ultima
tons of pictures at www.markkoch.net/canamMain.asp
Any body know what the normal egt is for an turbo ls1?
mark
Old Jun 27, 2005 | 11:20 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
1300 is a little high. Mine runs in the 1000-1100 deg range, this is at 13.5-14.0 AFR, but on an LT1 though that really shouldn't make much of a difference. Sound like it maybe a tad lean ,or not enough timing.
Jose
Old Jun 28, 2005 | 08:13 AM
Drewman's Avatar
God I love those cars. If I could only hit the lottery.
Old Jun 28, 2005 | 08:38 AM
BTL FED's Avatar
Is that 1300 at idle? if so something is WRONG. My diesel only runs about 300-400 degrees at idle, if I stand on it I can get it to about 1300 degree's.
Old Jun 28, 2005 | 12:51 PM
sb427f-car's Avatar
SSU'S Vice Mod
Where the hell are you in MD, PM me if you want, I'd love to see this thing in person, ride? ???
Old Jun 28, 2005 | 03:32 PM
y2khawk's Avatar
Diesels and gas engines are no comparison, gas engines run much hotter.
1300 at idle isn't too far off, a little on the hot side yes. At cruise, it's quite exceptable. it's ~700 C.
What's the wideband say? and what's your spark advance doing?
it's wide open you're really interested in, keep it under 1650 (~900 C) under full power and you'll be fine.
Old Jun 29, 2005 | 05:58 AM
BTL FED's Avatar
Wow, gas engines idle at 1300 degree's thats crazy I had no Idea, thanks for correcting me
