Best Forged piston for Forced Induction
Old Jul 1, 2005 | 04:07 PM
618HAWK's Avatar
Default Best Forged piston for Forced Induction
Looking for some insight on a good Forged Piston/Rings and Rod set up for forced induction. What seems to be the best way to go, not looking for a cheap way out but a strong and reliable setup.
Old Jul 1, 2005 | 07:10 PM
nitrorocket's Avatar
ANY piston manufacture is good. Wiseco makes an excellent selection of 2618 pistons for a really good price.
Old Jul 1, 2005 | 07:15 PM
2000 Tran Zam's Avatar
JE or diamond also make a good product.
Old Jul 1, 2005 | 08:07 PM
Boostaholic's Avatar
Wiseco gets my vote
Old Jul 1, 2005 | 08:18 PM
Slowhawk's Avatar
LS1Tech Sponsor
I've been ussing Diamonds on all my builds and they have worked out great.Just ran a 4.8l up to 18lbs today on pump gas without a hitch
Old Jul 1, 2005 | 09:37 PM
618HAWK's Avatar
Thanks keep it coming, what about rings is there any style to go with or stay away from with F/I.
Old Jul 2, 2005 | 09:10 AM
sb427f-car's Avatar
SSU'S Vice Mod
I think the majority of people say to stay away from the gapless rings, at least that's what I've read. Definately double check that. Hell fire seems to be a name that pops up quite a bit.
I've also been reading a lot about quench and squish pads in combustion chambers and piston designs to help focus cylinder pressures to where they are most effective and also fight det. Do you're research there as well.
Also think about coatings. Pricey, yes, worth it, well, when you're putting big $$ into a FI build, it's probably worth some HP and insurance. Good luck. Great thread too.
Old Jul 2, 2005 | 09:16 AM
n2oblkz's Avatar
I've purchased some Diamond Blower/Turbo pistons that I am going to have coated. Diamond's are made of the same Aluminum as the JE blower pistons at a lower price. I am also either going with Hellfire's or Plasma Moly rings.
Old Jul 2, 2005 | 09:21 AM
n2oblkz's Avatar
Here is some info on the types of aluminum that JE and Diamond uses that I found out while searching for my pistons.
I bought Diamond's D shaped Blower/turbo piston. They are a very good piston at a very good price. I did a lot of searching and found that most of the SRP pistons are made from 4032 aluminum which is a lower grade. If you check with JE, their pistons are made from 2618 aluminum which is a stronger, higher grade. Diamond's Blower piston is made of 2618 aluminum also and is a blower specific piston for the price of an SRP piston. Better materials, better price.....JMO!
Here is a quote from Diamond Racing's Q&A on their website.
Quote:
What material are your pistons made from?
We use two different materials, 2618 & 4032. 2618 is used in most of our severe duty / power adder applications. It requires slightly more piston to wall clearance and can stand up to the abuse of a power adder. 4032 is used for applications that are more on the mild side. 4032 has less of a expansion rate which allows us to use it with tighter piston to wall clearances. This is great for direct replacement factory pistons. Call one of our tech's and they will let you know which material is good for your application.
This is from SRP's description of their blower piston.
Quote:
8.0-11.1 Compression Ratio
Forged from 4032 low expansion high silicon aluminum alloy heat treated to SRP specifications
Ring land and crown thickness specifically engineered for turbo, supercharged and nitrous applications
Forced Pin Oiler for increased wrist pin lubrication
Pin fitting and double spiro locks included
927-2750-150 wall wrist pin (130 grams) included
CNC Machined ring grooves accept 1/16 1/16 3/16 rings (Rings Sold Seperately)
Optional tool steel pins available.
I know this is LT1 stuff, but the material aspect still carries over to their other pistons (LS1). Basically as far as I am concerned, Diamond makes just as good of a Blower/Turbo piston as JE (with the same material, the SRP's use a weaker material) at a better price.
Old Jul 2, 2005 | 10:06 AM
69firebird's Avatar
im using wiseco
Old Jul 2, 2005 | 10:18 AM
BTL FED's Avatar
What does everyone think of Mahle's?
Old Jul 2, 2005 | 10:49 AM
n2oblkz's Avatar
Postedby: BTL FED
I think that they are a very good piston (from what I hear and have read). I checked into them, they just didn't make a piston for my application and forced induction.
Old Jul 2, 2005 | 11:55 AM
69firebird's Avatar
Kyle,
Id call Erik Koeig at HPE, he spec'd my motor together for me and did a great job, and he actually reccomended some cheaper parts, that were stronger than what I originally called up to order.
Id call him, mahle's are pretty good, however i dont think they make a large enough dish for your stroker motor to lower compression enough???
Old Jul 2, 2005 | 02:48 PM
ddnspider's Avatar
pm Eric his username is racer7088.Weiseco here for me,but he's got Mahles too.
Old Jul 2, 2005 | 03:38 PM
69firebird's Avatar
well it depends on what kind of mahles you use, the ones that W2W sell are amazing units, the off the shelf ones prolly arent what your looking for either way
ed
Old Jul 2, 2005 | 04:24 PM
stevieturbo's Avatar
My Mahles/Callies rods just arrived today from Eric at HPE. I think they look pretty damn good.
I got them stock bore, with 16cc dish, which should place me around 8.5-8.7:1 CR, in readyness for as much boost as I can squeeze into it.
I'll know in about 3 weeks hopefully how they will all work out
Old Jul 2, 2005 | 05:05 PM
ddnspider's Avatar
i went with Callies rods as well so hopefully my Weiseco/Callies combo will look good and more importantly perform well.
Old Jul 2, 2005 | 05:58 PM
69firebird's Avatar
I got the callies, wiseco with like -26cc dish
Old Jul 2, 2005 | 06:03 PM
VTESPEED's Avatar
Does anyone know what alloy the Wiseco pistons are made from?
Old Jul 2, 2005 | 10:08 PM
eviltwins's Avatar
CP's have the closest piston-to-piston tolerance and general tolerances of any piston I've ever used. Diamond and Wiseco are right up there, I would definitely choose them over JE's.
