Got an issue that I can't figure out...
2002 Trans Am
STS T76 turbo w/ FMIC @ 7#
42# injectors and Racetronix fuel pump
Comp 918 springs
Jet-Hot long tubes
Wideband, Fuel Pressure, and boost gauge
TR6 plugs and Moroso wires
The problem(s) - not sure if they are related or what:
1) Cruising around at a set speed (no boost and not on cruise) I'll get an occasional hiccup where my A/F will skyrocket to 16-17 just for a brief second. This only happens after the car is hot and maybe once every couple of minutes.
2) Under boost A/F is fine, but a couple of weeks ago it started backfiring under boost. Turns out cylinder 6 was misfiring and replacing the plug made the problem go away. There was nothing visually wrong with the plug when replaced. *However* the plug wire had been laying against a header and was partially burned through (not to the core, but close). Today coming home the exact same thing happened, I was under boost and pop-pop-pop I started misfiring. I'm pretty sure I'm going to find it's cylinder 6 again.
Could the plug wire be causing my leaning while cruising and this (now) reoccuring problem with backfiring under boost? Are there other things I should be looking at (larger injectors? anything?)
Thanks much, this problem has me baffled - the car runs outstanding when it's running, but I'd like to get some ideas on what to do to get 'er fixed on a more permanent basis.
Check everything: fuel lines, fuel filters, all plus wires, all coil packs - make sure all are in good working order without breaks, flow or inadequate response.
The lean spike could be from the computer seeing issues with something electrical - wires or packs. Check them for continuity.
I have an autometer fuel pressure gauge, it reads 58-60psi all the time (both with the car running and off). I have no idea if that's good or not though
Easy to turn off if you have a editing tool.
J
J
