How long should meth last?
Old Jul 3, 2005 | 11:18 PM
ibgoatin's Avatar
Default How long should meth last?
I'm running a Snow Performance stage 2 set-up with the variable controller
It's set to come on at 4psi and max @ 10psi how long should this last?
It seems to use a lot of meth, I used 1/2 gallon in 10 minutes of "spirited" driving
Any insight would be appreciated.
Old Jul 4, 2005 | 05:05 AM
BOONE's Avatar
Default meth usage
I dont know anything about the snow kit but, i have a smc kit with a single m15 jet and with 10 or 12 dyno runs and a full gallon i had used about 80 to 90%. And ive raced 8 to 10 hard hits in a night and it will use probably 80% of it. But im not using a progressive controller. I held my line with the jet and turned it on once and it has quite a large volume coming out of it, it suprised me alot at how much.
Old Jul 4, 2005 | 08:49 PM
ibgoatin's Avatar
Thanks for the help-maybe i'll use my eboost or a w-o-t swith to turn it on so I don't use as much.
Thanks
Old Jul 6, 2005 | 08:33 AM
boosted99camaro's Avatar
I just installed my snow kit also.it does flow a lot of water/meth what size nozzle are you using.also did you feel a big increase in power.mine feels like I gained about 75-100 hp.
Old Jul 6, 2005 | 09:04 AM
cablebandit's Avatar
i use the windshield washer tank...uses about 3/4 of it after a night at the track. i have mine coming on around 10psi....watched the wideband at the track and you can really see where it comes in....i started leaning out that little window and 60' times pick up.
