STS silicone coupler
You can get a stronger elbow if bothers you though
Are you saying it is still shut when you have boost? I would make sure you are actually getting boost at that RPM as I have yet to see ANY boot like that compress when there is boost behind it! Double check if you are getting boost when it compresses down and go from there. I have had this problem with some of my N/A cars and we simply cut a piece of thin sheet metal neatly to fit inside the bellows to hold its shape and clamped the whole thing over the throttle body, we actually found quite a bit of power doing so as the thing was staying shut the whole time under load!
-Bryan
-Bryan
Shouldn't it be more like 4000-4500? The car is shifting around 6200-6300, but peaking at 5500 isn't giving it enough time to build the power it should be. Trending Topics
-Bryan
-Bryan
