Finally up and running again!!!
Old Jul 5, 2005 | 09:03 AM
MYTURBOT/A's Avatar
Default Finally up and running again!!!
Well i've been gone for awhile now, had some serious family problems and I thought I was gonna have to sell the car but now it's looking like i'm gonna be able to keep it.. Everythings back together now, with the fresh engine. Still running the lunati pistons, but I complimented them with a set of steel H-beams with 7/16 cap screws, main studs and new dimond moly rings.
I was having problems with the spec clutches so i picked up a mcloed twin disc which I still can't get to work right... I'm still trying to get the shimming right on the clutch so if anyone can point me in the right direction on how to setup this clutch I will forever be in your debt.
Finally got the chance to strap her down on the dyno but ran into a slipping clutch again Every pull the clutch would let go at 3800rpm then grab again at 5200rpm, WTF??? Numbers are gonna be amazing once i get all the kinks worked out. The car put down 520rwhp at 3900rpm And was climbing real hard when the clutch gave out.
I'll try to keep everyone update better now and look forward to any suggestions you might have on my clutch...
Old Jul 5, 2005 | 09:06 AM
smokinHawk's Avatar
its been forever what are the details of your set up, you have listed hand fabbed turbo kit with the masterpower.
edit: found it
for those who might be old and cant remember
https://ls1tech.com/forums/forced-induction/218057-new-kit-pretty-much-done.html
now i remember.
hopefully youll get that clutch figured out and get some good numbers.
Old Jul 5, 2005 | 10:29 AM
PHIL H's Avatar
Welcome back. I thought you fell off the face of the earth! Sounds like that beast is making some power though.. Keep us posted.
Phil
Old Jul 5, 2005 | 11:03 AM
MYTURBOT/A's Avatar
Thanks guys! So can anyone point me in the direction of a write up or any info on seting up this twin disc? I tryed a search but came up with nothing...
Old Jul 5, 2005 | 12:03 PM
smokinHawk's Avatar
INTMD8 has a twin disc set up, least last i heardmight try talking to him.
Old Jul 5, 2005 | 02:12 PM
Arkangel77's Avatar
Sounds Like its gona be a beast when you get it all worked out!
