LSX Kenne Belle's Soon
Old Jul 13, 2005 | 11:59 AM
phobos512's Avatar
Originally Posted by Got Me SOM
It'll work on a GTO but you may need to get a hood too. The Magnuson's sit in there just fine but I've heard that they have heating issues, too hot under the hood.
The heat issue with the Maggie has been fixed for several months through new tuning and modified fueling. Any Maggie kit for the GTO that you get now incorporates the fixes (and that is why I've got one in the mail).
You also don't need a new hood for the Maggie - some trimming of the stock heat shield and maybe a little of the inner hood layer is necessary but a new hood isn't.
Old Jul 13, 2005 | 12:21 PM
hpjunky98's Avatar
Originally Posted by dobe
actually just fab some solid motor mounts that lower the engine.. lots cheaper then getting someone to fab up a kmember... no i dont think it would change the entire drivetrain setup. but stuff like the headers might have to be modified
santore
See here’s where I get a little worried. lowering the engine is effecting the angle of the drive train, which is therefore altering the angle of the driveshaft relative to the transmission, which may cause problems with clearances of several things such as exhaust and suspension (not saying it will, I’m just not sure if there was an intention for the driveshaft to be angled in that way.) you can keep the entire drive train the way it is, but then you would have to use the rear axle as a sort of pivot, and fabricate new mounts for the rear shocks and springs etc. again, I’m not saying I’m sure this will cause problems, I’m just saying that altering the factory specs may cause more problems than you think. Either way, you would have a different angle for the transmission, which could require custom work on the transmission tunnel. Just thought id throw that out there. What do you guys think?
Old Jul 13, 2005 | 12:41 PM
LSX ENTHUSIAST's Avatar
Well the Stenod team have lowered the engine on Harlans TT hawk and their current project car. I dont remember if they used solid mounts or custom kmember, i dont know what else was done if any to the drive train. Maybe they can chime in and explain in more detail.
Ray
Old Jul 14, 2005 | 12:13 AM
hpjunky98's Avatar
ya that would be great. how can we contact them?
Old Jul 14, 2005 | 08:28 AM
777's Avatar
777
Ray
They had a plate running on the front instead of standard motor mounts.
Old Jul 14, 2005 | 11:06 AM
hpjunky98's Avatar
so what other mods were done to accomidate this if any?
Old Jul 14, 2005 | 01:05 PM
abadss's Avatar
i would love to see someone find a way to work this out. but it seems it has been tried by another company (the one pro stock john was working with) and the best result they came up with wa cutting the cowl and supplying a "patch" with the kit to clean up the cut area. the power would be awesome though
Old Jul 14, 2005 | 01:08 PM
777's Avatar
777
The mod list for Harlan's car goes on and on. He's changing stuff now, but he had twin t-66 turbo's, I think twin MAF's, billingsley fab 9", dry sumped, Auto tranny with trans brake and full manual valve body, stock cubes, stock crank, livernois heads (i believe), solid roller cam (don't know specs)....
Old Jul 14, 2005 | 04:54 PM
hpjunky98's Avatar
ya i was talking about drivetrain and suspension mods to accomidate the lowered motor.
