What is your coolant temp?
Old Jul 14, 2005 | 11:56 AM
cablebandit's Avatar
i forgot..i have an underdrive pulley as we.. I checked it on the interstate yesterday...90 degrees ambient and 205 with the a/c on. turn off a/c and it went to 198
Old Jul 14, 2005 | 02:22 PM
Phate's Avatar
Originally Posted by Zombie
I wonder if pulling it would help me out. I know people with other kinds of cars that pull their t-stat and seem to run cooler. Wonder if it would help me for summer.
I would be weary of pulling the t-stat...you need some kind of a restriction so that the water stays in the radiator long enough to get cool. You'd be better off drilling the t-stat out and keeping some type of restriction then pulling it out all together.
Old Jul 14, 2005 | 03:45 PM
sb427f-car's Avatar
SSU'S Vice Mod
Granted, a pure race application, but no race car runs a t-stat. As long as the system is properly designed, it'll be fine.
John, are you having any problems with doing that and are you on a stock rad.? Those who have removed the t-stat, are you on an aftermarket radiator or a stocker?
Old Jul 14, 2005 | 04:06 PM
FastKat's Avatar
Yes, the air has to go through the condensor before it goes to the radiator... afterall, they're only inches apart! With the A/C on, the condensor heats up and as a result heats all of the air before it gets to the radiator. I guess it's kind of like turning the ambient air temp up 20-30 degrees or so?
Originally Posted by tici
I was surprised to see the same high temp wit the AC on.
Why? Is it the heat from the AC heat exchanger that warms up the radiator?
I can't imagine that the extra stress of the compressor is robbing so much energy and the engine warms up!
Old Jul 14, 2005 | 04:46 PM
Phate's Avatar
I think that he is talking about a street car...not a race car. I have seen cars have overheating problems because they did not have any restriction to flow in the cooling system.
The system was properly designed from the factory with a t-stat, not without one.
Old Jul 14, 2005 | 07:36 PM
sb427f-car's Avatar
SSU'S Vice Mod
I think I implied that when I said "granted in a race car." My point being that with the proper radiator, fan, ect setup, it'll probably work just fine. BTW, I did also mention the use of an UDP to slow the water pump down to where it would work .
Old Jul 14, 2005 | 09:10 PM
Phate's Avatar
I guess I didn't see the relevance of the race car comment to the topic since we weren't talking about a race application. Kind of like me saying that some race cars don't run charging systems...although it is true it's not really what we were talking about
I think that pulling the t-stat is a band-aid solution to the problem that will ultimately hurt the reliability of the car. The t-stat is there to help the car get to operating temperature when cold...you lose this when you gut it. If there is a weak link in the cooling system then find the weak link and address the problem there. Just my .02 though
Old Jul 14, 2005 | 09:58 PM
2000silverbullet's Avatar
Does anyone run pusher fans in the front of thier radiator and puller in back? Would that help any?
