Turbo cams.
Old Jul 18, 2005 | 08:33 PM
ddnspider's Avatar
too big for daily driver like myself and i believe you too 69firebird.id rather idle like stock and make 600+rwhp then idle like a vicious rumbling beast and make 700+rwhp
Old Jul 19, 2005 | 08:57 AM
1point3liter's Avatar
Cam Motion spec'd a fairly mild cam for my setup. 228/223 574/576 115
I'm looking to make 600-650 on pump gas.
346 (8.2:1 compression)
3.902 Probe pistons / Eagle H-beams
317 mildly ported heads (stock valves) 918's
PT74 .85 A/R
3.9 gears, t56 trans, 2900lb
Old Jul 19, 2005 | 01:24 PM
JZ'sTA's Avatar
How would something like this work, for a STS kit?
Cam #1 (Lunati): 220.2/223.8 .553/.556 117.7* lsa
Old Jul 19, 2005 | 01:35 PM
Have you thought about calling Cam Motion and having them spec one for you?
Old Jul 19, 2005 | 01:45 PM
cablebandit's Avatar
what size motor and what size turbo on the STS...stick or auto?
Old Jul 19, 2005 | 02:15 PM
JZ'sTA's Avatar
346 stock bottom.
Auto
https://ls1tech.com/forums/showthrea...ight=220%2F224
For more info.
Old Jul 19, 2005 | 02:16 PM
JZ'sTA's Avatar
This is what I will more than likely end up doing.
I think for my goals the cam isn't going to be persect and for 400 bucks might as well get something right on the money.
Old Jul 19, 2005 | 02:37 PM
i think you oughta find something small....around 212 to 220 range to keep some bottom end and help spool. Get a 3200 stall and be done. I sold my Camotion spec'd cam and ran faster with a smaller one. Mightymouse made damn near 800rwhp on a stock cam!!
Old Jul 19, 2005 | 03:03 PM
JZ'sTA's Avatar
Maybe my theory is off and I will see once complete, however I feel that a larger stall would work better.
I am gonna try a 3800 Yank out and see how it works.
The reason is because I feel it will spool the turbo faster and get more RPM's quicker.
I dont mind shifting at 6500 RPM's even on a stock motor as I am more risky then most.
I have ran a mininum of a 150 shot through around 80 boddles on a stock shortblock and always shifted high.
I ran many 10sec passes running Nitrous and have given some thought as to staying with the Nitrous but really like The everyday power a Turbo gives.
I am gonna call cam motion and see what they spec, but I am defentially staying with a bigger converter and gonna test my theory.
Old Jul 19, 2005 | 04:09 PM
Our setups are different but I am taking my 3800 out and going BACK to the 3200 I had before....just like i took out the 3.73 gears i had and went BACK to 3.23s. Turbos like LOAD....I hope you will be happy with your setup and not waste money like I did.
Old Jul 19, 2005 | 04:32 PM
nossty1's Avatar
The cam i was talking about that i got shouldnt be very hard to get to idle nice with a 115lsa. This is also through a turbo car so the turbo will help it sound a little more tame.
Old Jul 20, 2005 | 12:57 AM
  #32
JZ'sTA's Avatar
Explain a little more if possible.
I am going on a theroy with the verter. This is something I have thought out myself and therefore there is plenty of room to be wrong.
I agree with the gear and I went with a 3.42 to be in the middle.
I have like 7 converters at my house and the 3800 seems like the closest for this project and that is why I picked it. Costs nothing.
Old Jul 20, 2005 | 11:03 AM
  #33
most of the turbo buick guys seem to find it best to get a stall that matches where you reach full boost.....i like your choice of gear....especially with 28" tires
Old Jul 20, 2005 | 03:24 PM
  #34
JZ'sTA's Avatar
Well in a rear mount with a large turbo maybe the 3800 will be fairly accurate.
With a Front mount Turbo then the 3200 seems like a more accurate choice.
Your running 10.12@137 and weighing 3820 so you doing something right.
Old Jul 20, 2005 | 03:26 PM
  #35
ddnspider's Avatar
i like to think he is as well what a and hes got some good tips too...like that boost actuated cutout.
