Turbo cams.
Old Jul 17, 2005 | 11:47 AM
JZ'sTA's Avatar
Default Turbo cams.
What cam works best in turbo setup's isn't brought up very often in this section. I was wondering what most use for their setup and why you ordered the cam you have?
Seems like some like a large triditional split while other run a reverse split cam. Lets hear what you got and if it works.
Old Jul 17, 2005 | 12:06 PM
Wicked_Hugger99's Avatar
225/225 .581 .581 on a 113lsa Works pretty good i think. Speed said if i went to big then id build boost to fast since i run a 6sp so they reccommended their street turbo cam
Old Jul 17, 2005 | 12:47 PM
nossty1's Avatar
I just orderd a fairly large cam from EPP, it should have been here fri but i am yet to recieve it. It is the same cam they used on a ttvette that made over 750rwhp i believe, but since ls1.com is down right now i cant look up the post and get the specs. I will let you know as soon as i find out.
Old Jul 17, 2005 | 01:29 PM
VSGLS1's Avatar
Looking for people with more cubes here to post up...
Old Jul 17, 2005 | 04:21 PM
ddnspider's Avatar
im going with a much tamer cam for my DD 383....called up Comp and talked to Futral....looks like something in the neighborhood of 226/222 .580/.580 115....Allen told me its a good idea for the reverse split since im using 02 manifolds...but will make 650rwhp no prob.
Old Jul 17, 2005 | 04:24 PM
ddnspider's Avatar
and you dont want too low of an lsa cause itll bleed off boost at high rpms....unless your CR is too high then itll help.
Old Jul 17, 2005 | 04:38 PM
69firebird's Avatar
erik specd me a 228 588 116+4 cam for my setup
should make good power, and be pretty tame
but most importantly make good power i want 700-750
Old Jul 17, 2005 | 04:42 PM
ddnspider's Avatar
thats a REALLY tame cam for a 346....and that +4 is really going to bring down your power band,almost too much.but i guess if he knows what hes talking about.What psi are you planning on making 700rwhp at?
Old Jul 17, 2005 | 08:00 PM
cablebandit's Avatar
I bought Mike browns old cam that he went 9.89 on in a 346 incon car. I just put down 746 dynojet with it today in my 346 incon car. it is HUGE!!! specs are 215/215 duration 567/567 lift 114lsa
Old Jul 17, 2005 | 08:06 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Cable, what longblock do you have? Did you dyno with Meth?
Back to topic, Terry @ Cam Motion typically reccomends smaller turbo cams, when you compare to say a supercharger cam.
Old Jul 17, 2005 | 08:19 PM
69firebird's Avatar
Yeah, I went over the whole setup, and I dont want to be shifting much past 6200.
I think the cam is pretty well matched to my setup all in all. I think hte power will be attainable at around 15psi. If not then more. Honelsty im going to run it up as high as I can safely on pump gas. once I run out of fuel im going ot come down a bit. if its 500rwhp, then so be it.
I really think it will be significantally higher than that
Old Jul 17, 2005 | 08:20 PM
PSJ...346 with bore for 3.905 diamond 9:1 pistons
lunati rods and stock crank...arp studs....head/main
317 heads...gtp s2
Hogzilla cam listed above
ls6 intake
And of course Methanol + 93 octane.
Old Jul 17, 2005 | 08:38 PM
TTSSZ's Avatar
you picked up 40rw with it over your last cam.
cant wait to see how that affects your et
Old Jul 17, 2005 | 10:50 PM
NA$TY-TA's Avatar
317 heads...gtp s2
ls6 intake
Thats bad *** man.... how much boost......???
Im going to look into a Meth kit for my new setup.......
I also need to ditch my current blower cam 230/236 .592/.602 on a 114+4 for something more turbo friendly....... anyone have any idea's for my 370ci????
Kyle
Old Jul 18, 2005 | 05:21 AM
TTSSZ....I dont think it will pick up anything until i figure out how to get off the line better. This was on 15.5 psi of boost. I wonder what your S2 turbos would make?!!!!
Old Jul 18, 2005 | 06:06 AM
BTL FED's Avatar
427 Solid Roller 266/259 727/729 116
Old Jul 18, 2005 | 08:07 AM
ddnspider's Avatar
im looking for that 650rwhp mark at 10#s....so i guess we'll c.You running 93 69firebird?
Old Jul 18, 2005 | 07:33 PM
nossty1's Avatar
Well here are those specs i said i would get to you earlier.
232/240 .595/.608 lift with a 115
Old Jul 18, 2005 | 08:15 PM
ddnspider's Avatar
that is a big cam!too big for my taste,but im sure itll make loads of power with a good setup.
Old Jul 18, 2005 | 08:21 PM
69firebird's Avatar
that is a pretty large cam, itd sure be nice to have a race setup with a cam like that
