ported heads with a Turbo
Old Jul 19, 2005 | 08:21 PM
Bryan Wilkinson's Avatar
Originally Posted by JZ'sTA
Do you guys believe a set of real good heads is important on turbo motor's?
Would it be a more power combo to do a set of 225 AFR's or spend the extra 2000 dollars on a better turbo setup?
I know stock vs ported the heads are better but are they good enough to make a 2000+ dollar purchase worth it?
The AFR's are not the best setup out there, however, with a 5/8" deck they will keep the heads planted under boost. Regardless of how much boost you start out with, you will always want to step it up a little more. I can say that without even knowing you, if you are even thinking about building a boosted setup and all of these people that say, I only want 600hp. Right!!!!!!, Once you feel it, you will want more, and the thicker deck heads will make a difference.
