car died!
Dr.X I might take you up on that. I'll let you know.
Anyone know how I check to see if the pumps are toast?
Then pull the entire sender assembly out and prime the key again, see which pump makes noise, if both are shot, all will be quiet, if one is shot....well one will be quiet..doubt there is anything wrong with the pumps....
Check the fuel filter, maybe it collapsed internally and is clogging stuff up...
Don't know if any of this is correct but it gives you a good place to start trouble shooting.
Cleaning the garage, tired of working on the car huh
prolly, take the sender out and see if your fuel line on the pumps failed...hopefully it did and not the fuel pumps.How long did you try to start it when it died on the side of the road?
J
-Geoff
ddnspider--funny you said that. I said to frcefed last night something about not caring about the car being f-up becasue I got to take it for a short ride. lol
White_Hawk-- well I have SS braided -8 line so it would be hard to crimp. But I disconnected the feed line right at the pump housing and turned the car on and still no fuel came out.
is where I got mine
He ships only USPS priority so you'll have em asap.J
J
