Does ls1 edit or hp tuners have a 2 step function?
Old Jul 21, 2005 | 12:17 PM
2000 Tran Zam's Avatar
Default Does ls1 edit or hp tuners have a 2 step function?
I was talking with one of my buddies last night, and he said for imports, with their tuning software they have a function in the programming that basically has the ability to turn off and on a 2 step feature.
Is that how our cars work, or is there a seperate device used?
Im thinking that would be a cool feature for future tuning software...
Old Jul 21, 2005 | 12:35 PM
slow's Avatar
Ford tuning software has this feature as well.
I have heard of people using it for HP tuners for the v6 f-cars , but not the V8's.
Ryan
Old Jul 21, 2005 | 01:05 PM
DERTY's Avatar
The Bull
There's no two step in the stock PCM. You can get one with a BS3 or another aftermarket one. Otherwise, look for a used Harlan two step somewhere.
Old Jul 21, 2005 | 01:19 PM
hmmmm, i think i might need to talk to allan about that, unless hes already though ahead for me...
how much does one run(assuming I can find one), and how hard is the installation?
Old Jul 21, 2005 | 01:50 PM
DERTY's Avatar
The Bull
Installation is very simple. Just a couple wires. Finding one, that's a different story. I'd suggest the for sale forum and see if you can find one. They are sort of a hot commodity at the moment.
Old Jul 21, 2005 | 06:28 PM
N20Silverado's Avatar
You could also buy the new MSD- LS1/LS6 box PN-6010 with the extra harness PN- 8886 which allows you to tie into the stock harness without cutting the stock harness and setting the SES light.
Features of the MSD box:
Pro-Data+ software
Plot timing curve vs. RPM
Plot timing advance vs. BOOST via 1,2 or 3 BAR MAP sensor Badass!!!!
Timing limit- Set min and max timing safety feature
2 step
step retard for N20
Idle Tiing Control- Used with OEM efi
I just received mine last week and was excited about all of the features it has. I wish the car was done so I could use it.
Tim
Old Jul 21, 2005 | 07:43 PM
ABeasst's Avatar
MSD's website says that ignition controller is for carburated applications not EFI
Old Jul 21, 2005 | 10:15 PM
I have the MSD box and instructions that came with it right in front of me. That is where the information came from in my previous post. I didn't just make it up.
Does their website say anything about the items I mentioned. NO. That is why I was excited to discover that it had features that I didn't know I was getting. (up to 3 BAR timing control!!!!!)
If you call them be prepared to get a few different stories. I was told on 2 different occations that this box wan not going to be released untill late fall. Then, 2 days later I get my new Summit catalog and there it is. I called Summit to see what they had to say: 3rd week of July release (It ended up coming a week early) I called MSD back the next day and they said, Oh, I guess that is when we are releasing it.
Tim
Old Jul 21, 2005 | 10:37 PM
ABeasst's Avatar
damn you need to chill the hell out I was just referring to the info on their site. Here is the link to THAT product MSD 6010
Thank you drive through
Old Jul 21, 2005 | 10:38 PM
I am just excited about all of the **** it will do that I didn't know I was getting.
Old Jul 21, 2005 | 10:47 PM
slow's Avatar
The ford stuff you can use the neutral rev limiter for the 2 step. It is just lowering a factory limiter.
One could assume that a gm pcm should be similar, but I am not sure how it works.
Ryan
Old Jul 22, 2005 | 09:12 PM
PHIL H's Avatar
Pro-Data+ software
2 step
step retard for N20
Tim
Sounds like a nice alternative to some of the other things out there.. How much is the 8886 harness?
Phil
Old Jul 22, 2005 | 11:21 PM
Phil
Phil,
I don't know the cost of the 8886. I am doing a carb setup.
Tim
Old Jul 23, 2005 | 07:03 AM
Slowhawk's Avatar
LS1Tech Sponsor
Ryan
You can do it in LS! software too
Old Jul 23, 2005 | 10:05 PM
Project GatTagO's Avatar
Care to elaborate?
Andrew
Old Jul 23, 2005 | 11:28 PM
Lostpatrolman's Avatar
http://www.hptuners.com/forum/YaBB.p...140763;start=0
Old Jul 24, 2005 | 09:24 AM
That thread is leading me to believe that for some reason this is not working on T56 V8 cars. The other questions I have is what pin on the ECU is the clutch switch?
I have an RX7 conversion and I do not have a clutch safety switch. Is the clutch safety switch a grounding switch or does it send +12v to a certain pin on the ECU? I would love to wire the line lock with the rev limiter.
Andrew
Old Jul 24, 2005 | 03:20 PM
ive got ls1 edit. does it have a feature on there?
or is it only hp tuners, or whats the dealio?
