Twin Turbo Fabrication on F-Body
Not 100% sure on this, but I think running twins for only 5-7psi would be sort of a waste... especially when you can get the same spool with one turbo.
Just my $.02, however I am curious to see what other people think!
What I still really think though is that you're going to have potential to make way more than 5-7psi!
Going just from the exducer bore, I am going to guess those turbos are good for around 400hp? each and that you will be able to easily get the 5-7psi you are looking for. I know this is probably a lousy estimation tool, but just using the turbine exducer bore suggests you're going to be able to spin the compressor fast enough to get your power without creating too much back pressure on the hot side. I would still calculate your CFM of airflow and pressure ratio, etc and check out some compressor maps to be sure on the compressor side.Where do you plan on getting your turbos from?
Yeah, to be realistic, 400 or so horsepower should come from each t3/t4, but they are advertised at over 500 and I see a lot of 4 and 6 banger cars using them or small 8's, hence me wanting to twin turbo it, at the going price of around $300! I plan to install the turbo's at the collector on my LT's or rear mount, not sure, that's why I wanted to run such small turbo's, and run twin CA's to the front of the car, or twin filters on the *** end, not sure yet, just kind of doing the paperwork now before I start this project. I would imagine I would need injectors bigger than 42's for this setup, what do you think?
Buy and read "Maximum Boost" by Corky Bell if you haven't already. It's a fantastic book (250 pgs) that outlines everything you need to know about designing and building your own turbo system. It will show you how to do the math to figure out what compressor you need, etc. JUST BUY THE BOOK! It will be the best $25 you spend on your turbo setup, period.
A rear mount setup with GREATLY impact the A/R ratio you need on the turbine housing.
42's will prob get you by on 5-7psi.
Don't know much about your other setup, but I'd say the 10:1 compression ratio is going to limit you on the amount of boost and timing you can run.
Recently (in the last two weeks or so) there have been a lot of twin turbo setup posts. Go back through the last few pages of listings and read them all.... they have some good info in them that you can apply to your setup.
Call Tom Izzo at Speed inc for more info.
As far as Turbos, contact John Craig at Limitengineering.com professional, affordable and knowledgable.
