HELP! Power loss after 5k.
Old Jul 25, 2005 | 09:40 AM
ON EDGE WS6's Avatar
Default HELP! Power loss after 5k.
I have a stainless steelworks kit with a T-76 Q-Trim Turbo. I’m having a problem with power loss at 5k. For some reason she runs like a champ 2k-5k making 390rwhp at 5psi, but at 5psi it drops about 200hp and we have to let out of it. I have the spark plugs gapped at .40. Do you think that it’s blowing out the spark? What other problems could it be? The wires are perfect. The only other thing I could think of that might be happening is the valves might be floating due to back pressure. I still have the crappy stockers in there, but I will get some 918’s if need be.
Here are some other components that I have installed that might be useful:
Racetronix PnP Pump
Motoron 60# injectors
Spec 3 clutch + billet FW
ARP Pro Series Rod Bolts
TurboXS RFL BOV
And a bunch of others just these are the ones that I thought might relate.
Any help is greatly appreciated.
Thanks,
Old Jul 25, 2005 | 09:54 AM
Race-Prep's Avatar
Suspended Sponsor
You are likely have valve float, I have seen many with this problem using the stock springs, they have very little pressure to begin with and if you add boost to that,the intake valves start having a hard time controlling the motion. Try the 918's and i will bet you have no more problem. I would say though the gap could be a little tighter if you run more than 5psi.
-Bryan
Old Jul 25, 2005 | 10:04 AM
PurEvl's Avatar
valve float...get the 918's in there
Old Jul 25, 2005 | 02:06 PM
99SS-T's Avatar
100% valve float. Mine did the same exact thing with teh stockers. Make sure to get hardend pushrods when you do teh valve springs as they are prolly a little distorted. GL
John
Old Jul 25, 2005 | 02:11 PM
ddnspider's Avatar
definitely the springs,others have been in the same boat and that fixed it right up.Due to the FI it puts more force on the springs.
Old Jul 25, 2005 | 02:27 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
More than likely it's valve float.
If it was a plug gap issue the car wouldn't fall of that much.
Old Jul 25, 2005 | 02:46 PM
ddnspider's Avatar
hey On Edge how do you like your BOV?ive heard mixed things about them and have 1 waiting to be installed but not sure if i should.
Old Jul 25, 2005 | 10:29 PM
FastKat's Avatar
Are the 918's the strongest of the Comp springs, or just the next step up from LS6 springs?? What are the other Comp ones?
Old Jul 25, 2005 | 11:16 PM
NA$TY-TA's Avatar
Most people use them because they work... when usung a low lift cam when you have no need for a double spring... and there cheap $159
Kyle
Old Jul 25, 2005 | 11:25 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
The 918's are the strongest beehive spring comp makes. They do make a stronger dual spring setup, but most people don't need them. As someone else replied earlier, REPLACE PUSHRODS anytime you upgrade anything in the valvetrain, the factory ones bend easy.
Old Jul 26, 2005 | 03:22 AM
HossinatorSS's Avatar
i've been researching this topic too in preparation for my sts kit. i'd say it's valve flutter. i think there's some specials/gp's going on for comp cams stuff right now in the sales forum. of course, once you're there you might as well do PR, TI retainers, rocker arms........it never stops!
Old Jul 26, 2005 | 08:52 AM
FastKat's Avatar
Does too strong of a spring cause additional resistance when the engine is running, or is one spring compressing offset by another spring releasing, etc?
Old Jul 26, 2005 | 09:37 AM
As far as the question(s) about the BOV: It seems to be working good for me. Im pretty sure that its loud, but with my 3" open downpipe its still kinda hard to hear. I can hear it. Its just not crazy loud over my exhaust.
I will definately upgrade the pushrods, but Im not getting into the rocker arms and titanium retainers yet. Im going to purchase a set of 6.0 heads have them ported and then I will buy the valvetrain components for those heads. Right now Im just trying to fix the current problem without getting all the way down to "Well I might as well pull the motor and go all forged etc."
Thanks for everyones help.
Old Jul 26, 2005 | 10:17 AM
LS1Tech Co-Founder
No, with FI you need more spring than stock. Adding boost makes it harder for the valves to snap open, because the charge is pushing the valves closed.
I made some changes to my combos and started to float my Crane 832's. My car dropped like a stone at 6200. Intmd8 and I did some research, and went with the Comp 977's. Now the car peaks up at 6500-6600 again, and now just appears to be intake limited.
Old Jul 26, 2005 | 10:20 AM
What gap is everyone running? Should I gap my plugs at .35 or .30?
Old Jul 26, 2005 | 10:45 AM
LS1Tech Co-Founder
.035 gap
Old Jul 26, 2005 | 10:46 AM
.035 gap
Right on.. Thanks.
Old Jul 26, 2005 | 11:18 AM
RealQuick's Avatar
I think you meant to say:
Adding boost makes it harder for the valves to snap closed, because the charge is pushing the valves open....
Right??
Old Jul 26, 2005 | 03:26 PM
99SS-T's Avatar
We can only hope lol
John
Old Jul 26, 2005 | 03:30 PM
You guys are too critcal.
