anyone have a medium frame to try?
Old Jul 27, 2005 | 09:54 AM
sb427f-car's Avatar
SSU'S Vice Mod
Originally Posted by JZ 97 SS 1500
Ok first, PTE does have the mock-ups. If you can't get one, give me a call Dave, we will call PTE for you. Next, the PTE88 T4 vs T6 leaves about 250-300hp at the table due to the T4 compressor cover, and T4 flange. Wheels are the same in both. As for the size of the PTE88, compressor cover is the same as the T76, the only thing different is the turbine housing is larger and comes in either a 4" vband, and 3" donut flange. We have been able to squeeze 1012rwhp with the 3" donut flange.
Jose
Dang Considering the possibility with just a T-4 flanged 88, no need to worry about the space of the T6 flanged for an extra ohhhh 250-300 hp.
Old Jul 27, 2005 | 11:24 AM
MIGHTYMOUSE's Avatar
smokin, can you find the pics of when they did that? i didnt think they finished it/didnt recall it being an 88mm.
jz the t4 flange vs the t6 flange would have no spool time difference?
Old Jul 27, 2005 | 11:36 AM
sb427f-car's Avatar
SSU'S Vice Mod
I was thinking that it would, but when he said same compressor and turbine wheel, wouldn't that mean the same weight, and therefore same spool? Other than the larger housing which would effect it, but I guess that's made up with the velocity out of the 4" v-band outlet of the turbine housing?
Old Jul 27, 2005 | 11:43 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
They do use the same wheels, now spool up is about the same. Reason being, a .96 A/R is a .96 A/R doesn't really matter the flange size. The T6 though does allows more volume of air into the scroll area. So with that I prefer to use the largest flange possible, whenever possible.
Old Jul 27, 2005 | 11:47 AM
smokinHawk's Avatar
Give me your email and ill send the pics i have, i saved a bunch on my keyfob.
Old Jul 27, 2005 | 11:51 AM
mightym0use@comcast.net
Old Jul 27, 2005 | 12:02 PM
sb427f-car's Avatar
SSU'S Vice Mod
uh oh, hum.
Old Jul 27, 2005 | 12:09 PM
smokinHawk's Avatar
i forgot i took them off my keyfob to fit some school crap on it, so i put it on my hard drive at home. ill have to get them later.
i tried searching on ls1com, but that site is down.
Old Jul 28, 2005 | 12:13 PM
Originally Posted by BOOSTNSS
i got a couple of them you looking for a T-6 right pm if you still need one
psst.. i pm'd you.
Old Jul 29, 2005 | 04:32 AM
KAOS's Avatar
what are you going to do with your old turbo? i could have some good plans for it if you were just going to trash it
Old Jul 29, 2005 | 05:52 AM
smokinHawk's Avatar
Check your email dave
warning its not so dail up freindly, about 6megs of pics.
this was his old site but its not there any more
http://www.disavowband.com/images/Carpics/
Old Jul 29, 2005 | 01:05 PM
  #32
kaos ill let you know if it goes on the market
