anyone have a medium frame to try?
Old Jul 25, 2005 | 06:53 PM
MIGHTYMOUSE's Avatar
Default anyone have a medium frame to try?
for test fit.. can certainly be broken, or an empty housing.. i promise to return it
i believe the only option is the pt-88?
thanks
Old Jul 25, 2005 | 08:38 PM
sb427f-car's Avatar
SSU'S Vice Mod
Dave, what are you doing?
Old Jul 25, 2005 | 08:45 PM
DMH Fabrication's Avatar
what turbo you running now mm? which flange are you looking for on the pt88 to test fit it?
Old Jul 25, 2005 | 08:51 PM
either one.
right now the car has a 76mm from turbo people.
what i want to do is obvious
Old Jul 25, 2005 | 11:25 PM
qqwqeqwrqwqtq's Avatar
I think precision will send you a mock up turbo if you send them a (refundable) deposit.
The mid frame Innovative 88 on our shop car has a T6 inlet, I think you're correct in thinking that precision is the only one that makes a T4 flanged 88.
Have you ran your car yet this year with the new motor?
Old Jul 26, 2005 | 05:20 AM
NA$TY-TA's Avatar
Damn Dave............. another one........
Old Jul 26, 2005 | 06:52 AM
ive run the car a bunch, nothing good has come of it yet.
since the start of this season i'm on my:
2nd clutch, 3rd ouput shaft, 2nd driveshaft slip yoke, 2nd ring and pinion, 2nd set of street tires
Old Jul 26, 2005 | 07:24 AM
Tiago's Avatar
yikes .....and you want more
Old Jul 26, 2005 | 08:51 AM
sb427f-car's Avatar
SSU'S Vice Mod
Yeah I knew you had been having problems with driveline stuff. Got that sorted out yet?
Old Jul 26, 2005 | 10:35 AM
red90cobra's Avatar
ouch, lol always something though hope your luck gets better
Old Jul 26, 2005 | 12:43 PM
Z06PSI's Avatar
Fighting the inevitible Auto swap huh.....
Old Jul 26, 2005 | 02:43 PM
if i can make it through this season i'll be home free.. until next season
stuff in there nows supposed to be stronger. (viper shaft, billet slip yoke)
i guess i should call to see how much that core deposit is from precision
Old Jul 26, 2005 | 02:54 PM
sb427f-car's Avatar
SSU'S Vice Mod
General question...Precission is the only one that makes the mid frame 88, obviously. Other than smaller physical size for tight engine compartments, is there any advantage or disadvantage to a T4 flanged 88 vs a T6 flanged 88? I got to thinking about that last night. Airflow and IATs any different and make an improvement for pump gas applications? Obviously there is a big difference in turbine size and outlet size for DPs, but how much is theoretically being left on the table by just being in a mid vs thumper frame? All else being equal.
Old Jul 26, 2005 | 05:53 PM
NA$TY-TA's Avatar
Thants a good question...... David ask them that when ya call..... Any word? Did ya call allready???
Kyle
Old Jul 27, 2005 | 06:54 AM
smokinHawk's Avatar
Dave do you remember the guy over on ls1dotcom with the tti race kit who put the PTE88 in there., i looked at his pics and one problem was the water pump, he had to use an electrical one. as the outlets would have hit the turbo., on my setup it was very close to the pump as well.
i do believe he did get it to fit though, if you do some searching overthere you can problably find his posts
id let you borrow mine, but i need to finish it up this month...hopefully.
Old Jul 27, 2005 | 07:02 AM
BOOSTNSS's Avatar
i got a couple of them you looking for a T-6 right pm if you still need one
Old Jul 27, 2005 | 09:30 AM
sb427f-car's Avatar
SSU'S Vice Mod
when are you gonna have pics up of your newly fabbed setup? how's it coming along?
Old Jul 27, 2005 | 09:35 AM
smokinHawk's Avatar
im hoping to get it done by the TA nats, but not sure if its going to happen.
guess i could show some pics now, i just dread the boards nagging on when im going to get it done, been working on it for a year now, here and there as my schudaul permits, i havent worked on it for two months now as been busy with school, and got married last week.
should start on it again soon.
you can check my new post for pics.
Old Jul 27, 2005 | 09:47 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Ok first, PTE does have the mock-ups. If you can't get one, give me a call Dave, we will call PTE for you. Next, the PTE88 T4 vs T6 leaves about 250-300hp at the table due to the T4 compressor cover, and T4 flange. Wheels are the same in both. As for the size of the PTE88, compressor cover is the same as the T76, the only thing different is the turbine housing is larger and comes in either a 4" vband, and 3" donut flange. We have been able to squeeze 1012rwhp with the 3" donut flange.
Jose
Old Jul 27, 2005 | 09:48 AM
sb427f-car's Avatar
SSU'S Vice Mod
cool deal. Hey I think we all understand busy schedules, lack of funds, and never enough beer in the fridge when wrenching.
