what converter when running a turbo..
I would not rush into doing a converter that is rated for 3500 or higher stall unless you are mostly going to race, and have talked to the manufacturer to discuss how that it will actually stall with the added power of a turbo. Don't forget to install at least a 19,000 GVW rated trans cooler to extend the life of your transmission.
If you can ever get a Neil Chance...DO IT>
and who is this neil chance dude
If you have a 3000 stall in the car now, I'd leave it alone and see what happens.
$2000 for a good bolt-together (2-piece).
$3000 for an ultra-light mack daddy bolt-together.
I got mine for $1425 shipped (pro mod weld together it was called).
You're not going to be pushing a lot of power with 10 psi so i would most converters would hold the power with maybe 200 rpm slip at most.
