Custom turbo?
Old Jul 25, 2005 | 10:02 PM
Tim_WS6's Avatar
Default Custom turbo?
i might have the possibility to get my hands on a turbo from an old 3000gt, and i was just kinda curious if it was possible to have it custom made to work for my car? also what kind of price range? i know all the lines and fittings would have to be custom made, but is this something that a shop could realistically do fairly cheap? i dont really know anything about turbos.
Old Jul 25, 2005 | 10:22 PM
FastKat's Avatar
If you're at all serious about putting a turbo on your car, buy "Maximum Boost" by Corky Bell. This book goes over turbo systems front to back and gives you a good deal of advice on building your own turbo. It's not a very hard read, but it's not some guy blabbing on and on about stupid stuff either. It'll be the best $25 you spend on your turbo system. It's A LOT of good information... JUST BUY IT!!!
Old Jul 25, 2005 | 10:45 PM
StoleIt's Avatar
NKAWTG...N
if the 3000gt had a turbo it was a vr4, which means it was originally twin turbo. those turbo's are really really small. u'll max it beyond maxing out. i think u could use 4 of those turbos, but that would be the minimum amount.
Old Jul 25, 2005 | 11:04 PM
Mike 01WS6's Avatar
WASTE of your time. Get a turbo that will actually work on this motor. Those small as turbos will be maxed in no time. You'd get more power from bolt-ons and cam, while coming in a whole lot cheaper too.
Go get a turbo sized for your motor and build from there.
Old Jul 25, 2005 | 11:06 PM
EightBall's Avatar
let me suggest, in that case, earning the necessary dough to hire a shop to build you a car, or spend at least a year on these boards and elsewhere gaining as much information as you can on the subject. This is an area that you really can't go into with no knowledge whatsoever.
Old Jul 26, 2005 | 07:08 PM
Tim_WS6's Avatar
i decided im not gonna mess with it. i'll just save up for heads and cam.
Old Jul 26, 2005 | 09:15 PM
69firebird's Avatar
Yeah thats a good idea, I did a turbo swap on a vr4, the upgraded 13g turbos we put on were tiny, the stockers are the smallest turbos I have ever personally seen. Didnt even make a decent paper weight. Youd have maximum flow at idle id imangine with those tiny turbos.
we since upgraded his car to 14b's and they are a decent sized turbo, two of those may be a plausable upgrade (there stock turbos from eclipes')
