cutting front bumper for FMIC
Old Jul 26, 2005 | 02:39 PM
94formulabird's Avatar
Default cutting front bumper for FMIC
I am cutting my bumper today for my fmic on my camaro. What did you guys use to cut yours and how did you go about doing it. Not sure exactly what to use to cut it with. THanks alot
Old Jul 26, 2005 | 02:52 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
A boxcutter (razor knife) worked on my 98 Formula. Just be conservative at the beginning and then cut more.
Old Jul 26, 2005 | 02:56 PM
99SS-T's Avatar
I first took a marker and stenciled wher i wanted to cut. Then i used my Sawzall with a bimetal blade that isnt agressive. I then cut on the line and it worked GREAT. I work with sawzalls all day as im in construction so i have some control over it but it is definatly alot easier then a kinfe of any sort. GL
John
Old Jul 26, 2005 | 03:02 PM
frcefed98's Avatar
Sawzall, razor blade....man thats asking for stichesJ/K guys. I used a dremel with a cut off wheel(s) it made quick work of the bumper cover.
J
Old Jul 26, 2005 | 03:54 PM
Brains's Avatar
Die grinder with a 4" diameter cutoff wheel. Made a very nice, smooth cut.
Old Jul 26, 2005 | 08:43 PM
BLk01SS's Avatar
took my time and drew a line, then used a sawzaw. Then used a hacksaw blade to do the fine work. went back with sandpaper and got a good finish. takes awhile to get it right, and your gonna think you lost it when you cut it out, but it will get ya more flow and make it stand out.
Old Jul 26, 2005 | 11:34 PM
libertine1015's Avatar
Rotozip, cut like butter, small and easy to control. Then put on a tootsie roll and tune it right in
Old Jul 28, 2005 | 06:15 AM
JIMMYZZ28's Avatar
If you use a sawzall go with at least 24 tpi.
Old Jul 28, 2005 | 08:46 AM
KAOS's Avatar
razor blade here. if you are talking about the plastic bumper. i dont see using a sawzaw or die grinder but hey if it works. be careful. i ended up with 6 stitches and still no feeling in the tip of my finger and this was 2 weeks ago. good luck though
Old Jul 28, 2005 | 12:42 PM
jwitt2's Avatar
so anyone have any pic's of thier fmic?? very interested in what it looks like.
Old Jul 28, 2005 | 12:53 PM
jwitt2's Avatar
never mind i saw the post from a few weeks ago.
