Best place to Find a GMPP intake
Kurt
You can get it with the rails but it is a different part # in that configuration
where did you get yours? and will the ls1 or ls2 rails work?
Damit the easy way out is gone now ..lol
the Prices were 318.99 for just the intake and 402.99 with the fuel rail kit
Anyone know where someone has one in stock ?
your Gonna need a elbow of some sort to make it work aswell and a Tb with Tps and Iac setup on it
Here is a breakdown
If you use a Wilson TB or FAST TB, both of them are using a Ford TPS sensor. Works with the GM computer, but the wiring is different. A company called ASSC makes a IAC adapter out of aluminum that mounts to the TB for use with the Wilson piece.
Wilson will do the Bungs, mount the Fuel rails, and machine work for you and setup the TB and elbow. They have a 90 and a 105.
Your local GM dealership has the Intake. I paid a little more for mine but the benefit of getting from the dealer was no shipping cost.
and what is the part number WITH the fuel rails? i just see it in this post w/o the rails. and the ones that come machined and with the rails is "basic" plug and play in regards to setting the injectors in place?
