Procharger P-1SC install ?s
Old Jul 30, 2005 | 08:44 AM
wicked_95z's Avatar
Default Procharger P-1SC install ?s
I've got most of it done just need a sanity check. Its on a 95 LT1 if taht helps
#1 Does anyone have pics of how the filter and MAf sit up in the fender well? I seem to be having some diffuculty getting it situated
#2 What do I do with the vacuum lines form the opti? I've though about drilling two holes in the intake side of the charger and sticking them in there so they always have vacuum like OEm.
#3 Has anyone left there OEM PCV system the way it was? I left mine stock and put two breathers in the pass. valve cover. Will this suffice?
#4 those who are venting the bypass to atm. what are you using to block of the place where it goes back into the intake track of the supercharger?
Thanks everyone. Hoping to fire the new motor off tomm and I want everything to be right.
