Need info on Holset turbos...
Maybe. Remember, Diesels aren't meant to rev nearly as much as a gas motor.
I'm with you sandman, definitely don't want to be playing in that ball field unless you have some seriously deep pockets. The one that has been rebuilt goes as follows:
Assembly: 3527102
Serial: 314170
Type: HT80
The 'spare':
Assembly: 3527102
Serial: H0001031
Type: HT80
I don't have a digital camera, but beleive me when I say these things are HUGE. The Mandingo of turbos. It looks like they might require at least a 6" downpipe, but I didn't have my tape measure with me. Does this info help any?
but with a 350-400ci v8, it'll be slow to spool that high.
the problem with most holsets on gas V8, is that they LIKE high pressures.. they're more efficent at pushing volume at high pressure then at lower pressures.. donno how that works, but it fits with everything ive read/seen.
i have a few holsets myself... without getting into it, brand new cummins turbodiesel engines are brought into a local plant a friend works at.. they convert these land diesels for marine use... and replace the holset on the brand new motor with a diffrent one.
they then scrap the turbos.... most of them are FAR too large to keep, but i have a few HX35s, HX40 going on my car, couple 55s, ect.....
