2 step wiring
Old Aug 2, 2005 | 02:58 PM
cablebandit's Avatar
Default 2 step wiring
Yeah I searched but i need a damn color picture or even a video with my lack of electronics understanding. I want to change my 2 step to activate/deactivate manually. Right now it is on a momentary switch and the brake pedal switch and releases when i let off the brakes. I would like to wire it to activate/release off one button like maybe one of the radio control buttons on the steering wheel.
Basically i want to stage...press and hold a button to activate 2 step......floor it and release button when i am ready to release 2 step and go. Can this be done?
Old Aug 2, 2005 | 03:20 PM
y2khawk's Avatar
Move the gray wire to a permanent ground.
run the white wire to your button.
Old Aug 2, 2005 | 03:23 PM
oh snap!! headed outside now!!! Thanks harlan.
Old Aug 2, 2005 | 05:02 PM
works like a charm!!! Thanx....hoping this will eliminate the delay between release of pedal and time it makes contact with brake light switch. even .05 in the 60' is worth the little bit of work
