my 2 step wasteful thoughts
Old Aug 2, 2005 | 07:00 PM
cablebandit's Avatar
Default my 2 step wasteful thoughts
just my random thoughts
Working on my 60's...best is a 1.54 and trying to find a way to get this pig moving without a t-brake. I tried the hydroboost brake system.....it gave me more brake pressure via the power steering pump. Did hold maybe 200rpms more but was SLOOOOOWWW to release fully. car would roll 10' before the brake pedal got back to the top to hit the brake switch and deactivate the 2 step. So today i put vacuum brake booster back in. I watched how fast the stock setup returns and noticed it took maybe .5-.75 seconds to get back to the top and trip the brake switch. HMMMM i am thinking. Maybe at the track, the car is rolling 5 feet before it actually comes off the 2 step. So this weekend I am going to try it on a button. I dunno if i will actually gain anything but even .05 in the 60' would be an awesome gain to me. I also have a abs delete kit from SMJ coming. With the adjustable proportioning valve, i should be able to get 50% of the pressure to the back instead of the factory 30%. This might help me hold more rpms on the 2 step and launch a little harder. I am sure most of you are thinking but maybe it will work!! I'll post the results.
Old Aug 2, 2005 | 07:23 PM
paspar2's Avatar
What are the difficulties with putting a trans brake on a camaro? wouldn't it give you the results you want?
Old Aug 2, 2005 | 07:48 PM
BOOSTNSS's Avatar
Default ????
would like to hear how it turns out cause a t-break and that weight could be expensive but i have the same probs with my setup so would like to hear the outcome later
Old Aug 2, 2005 | 08:20 PM
t-brake wont work on a 4l60e as of now. besides, with a t-brake, i couldnt use my stock rear!!!
Old Aug 2, 2005 | 09:19 PM
quicksilverado's Avatar
When you get to the times you are running Jerry .05 is a lot especially the 60'. Thanks for the help tonite.
Old Aug 2, 2005 | 09:40 PM
lol....left the house unlocked but locked the keys in the turbo'd truck.....i see you have your priorities in line!!
Old Aug 2, 2005 | 09:41 PM
TwnTrboCE's Avatar
A hand held switch would deffinately be faster. We use the switch that comes with the Hurst Roll Control. Very fast. I have about 18" of the wire that comes out of the center console. The switch has a rubber sleave on it thats is supposed to slide over a shifter lever. But I took a lip tie and put it thru the side of it. Making a loop. I then take this and slide it over the end of the E-brake handle. Works great. When not in use I slide it off and put it in the console. Street car you know.
Old Aug 2, 2005 | 10:11 PM
good idea...i am wiring mine to the "set" button on the cruis/wiper stalk. it's the one on the end you push in. mike i am always one step behind you....prolly why i am one second behind you too I bet you like the street car part!!! With my boost activated cutouts and stock catback, people always when i reply to their "whats it run/ how much power" questions. I am gonna start lying...runs 12s with a 100 dry shot!!
