are turbos bad on gas milage?
on the way to the n vs s event, I filled up and jumped straight on the xway, ran till almost empty and filled up, got 27.4 mpg. 3850# car, and 3.73's (6 speed). at stock weight and 3.42's I bet I would see almost 30.
BUT in everyday driving, I can bring that average down to 19-22 mpg, from tank to tank. 40% city driving. so I know that when I lean into it, those 42#ers are pouring in the fuel. city mileage is probably 13-15?
cant wait till the 60's go in......
Pure BS....the crap is deep in here
BTW, turbos don't give you better gas mileage
on a petro motor.....lol The Best V8 Stories One Small Block at Time
interesting stuff.
interesting stuff.
Diesels are throttled by fuel, not air like a gas motor. Add to that that they work off of auto ignition (basically they are designed to detonate) and that's why you can put nitrous, propane, and 50+ #s of boost to them. Obviously the more fuel you put to the diesel the hotter it will burn (up with the optimum ignition temps) that's why turbos are used with them, as it allows the more fuel to be added, since it still is an air pump. Turbos were basically used to control soot emmissions from diesels but boy have they caught on with the peformance aftermarket. As far as turbocharging tech. for diesels they are lightyears ahead of gasoline and other "spark" lit fuels.
EDIT: Most of the injectors run at fuel pressures in excess of 24k psi. Fuel pumps have flow rates that probably compair to Fuel motors (in terms of rail pressues). I don't know if you caught HotRod yest this month, but they have a great article in there about Diesel performance. Also, clean diesel and bio diesel will probably earmark future transportation, and if the performance industry can find ways to make awsome diesel performance cars / trucks, I'm game!
As stated above, a turbo increases the efficiency of the engine. When an engine is operating at or near peak efficiency, you may see an improvement in the mileage noted. OEM's are looking more and more at turbos for this reason. It also allows them to make the same power out of a smaller engine, thus improving fuel economy. Less fuel needed in a smaller motor.
If your turbo/motor (at lower boosts 5-8psi) are set up correctly, you should see similar mileage as you had N/A. Now that will not be the case for those with a race set-up (higher boosts over 8psi). Those setups will require higher flow injectors which common sense will tell you requires more fuel and that will probably bring your MPG down some.
Honestly smokin...i was seriously thinking about if this T/A deal falls through (finally looking her over on saturday), saving money for another year and trading the malibu on a low miles TDI jetta or golf. 46 MPG is better than ~30 even though diesel is a bit more expensive than regular unleaded.
lol
