are turbos bad on gas milage?
Um, not a well matched turbine housing! Fact of it is that when you aren't on boost, it drives much like a NA car. Since there is no extra pulley to drive (supercharger) you don't really sacrifice mechanical drag on the motor. Most of the arguements for better mileage come from extra tq in a higher gear which = less down shifting. As long as you aren't crazy, you shouldn't see that much of a decrease in fuel mileage.EDIT: back-pressure should be a negliagable increase off boost, that's what I meant to say.
They can improve gas milage, but rarely do because the of excessive throttle manipulation
They have also been known to wear brakes out a lot faster too.
For example a turbo diesel will have better economy over an equivilant N/A diesel for two specific reasons
1) The turbo makes use of heat recovery
2) The diesel engine can be a smaller cubic equivilant and still move the same amount of air due to the turbo.
Our cars loose gas mileage with a turbo because it does not contribute to the normal driving cycle. It simply rides shotgun in your exhaust obstructing flow until YOU want more power. Industrial turbo's are built to provide boost during normal operating conditions which does make the cycle more efficient
Here's the challenge
Someone show me a US sold passenger car that we can take the (funcitonal) turbo off of and actually get worse gas mileage during normal, everyday conservative driving.Here's the challenge
Someone show me a US sold passenger car that we can take the (funcitonal) turbo off of and actually get worse gas mileage during normal, everyday conservative driving.heres an idea though. ask pur evil how much mpg he is getting right now with his NA 408(with turbo internals) and then compare it to after he puts the turbo on. then we can see exactly what changes and what doesnt.
That's a great idea, get him to do a "normal" driving cycle for 1~2 tanks, mix in city and highway, with "some" light and full throttle accels, before and after. Then we'll have some real world #s.
The closest thing I can think of is a TDI VW... but that's it.
