help with Vortech crank pulley
Old Aug 12, 2005 | 04:33 AM
camarossrulz's Avatar
Default help with Vortech crank pulley
This crazy pulley keeps working loose. I have torqued it to the correct specs and used a new bolt. Any one else have this problem and know a cure?
Old Aug 12, 2005 | 06:22 AM
2001WS6Vert's Avatar
http://www.atiperformanceproducts.co...s/damperparts/
Old Aug 12, 2005 | 07:07 AM
has anyone used this kit and how does it work? Is there anything else I need beside the kit?
Old Aug 12, 2005 | 12:01 PM
It works great and its all you need. The groove in the Vortech pulley fits perfectly. If you have a forged crank it is more difficult to drill the crank properly. I ended up keying my forged crank because I didn't drill the hole clean and the pin wobbled.
Old Aug 12, 2005 | 12:13 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I run a Vortech crank pulley setup just like the from your kit, and mine is keyed. I have never had problems with the crank pulley setup in the last two years.
Old Aug 12, 2005 | 01:52 PM
I think I am going to get it. I have the stock crank so it should not be to bad to drill. I know it will keep the pulley from spinning on the shaft but will it help hold the pulley on?
Old Aug 12, 2005 | 05:51 PM
Inspector12's Avatar
TT-TECH Veteran
I ran the pin kit that ATI sells and it was fine easy to drill just follow the instructions and it will be easy.
Old Aug 13, 2005 | 04:42 AM
thanks for the help, I need to order my kit
