Casper is now there!!!!
Old Aug 16, 2005 | 12:17 AM
  #61
LINGENFELTER SS's Avatar
Congrats on getting into the 6's !!!
Old Aug 16, 2005 | 12:25 AM
  #62
red90cobra's Avatar
wow thats flyin
Old Aug 16, 2005 | 03:53 AM
  #63
Anti-Vnm's Avatar
Pfft... ....weak!
Old Aug 16, 2005 | 07:23 AM
  #64
FSTR-THANU's Avatar
Outlaw 10.5 Director
Kurt,
Is that still with the AFR heads?
Tom
Old Aug 16, 2005 | 07:51 AM
  #65
427's Avatar
427
Kevin is working on the video's now. The 7.04 run video is the best to watch because Mike only pulled one chute and ended up in the sand. He takes the car into the sand sideways so nothing goes into the turbo's! The 6.86 video is good also, you can see him correct after the wheels touchdown. Then the windshield bends in!
Tom- I still have my welded up AFR's on the engine.
Kurt
Old Aug 16, 2005 | 07:56 AM
  #66
smokinHawk's Avatar
in car video perhaps?
http://www.w2wpowertrain.com/images_...spr6.86run.wmv
Old Aug 16, 2005 | 09:03 AM
  #67
Reckless's Avatar
Super Moderator
What is the link Jon? tried to fix it with no luck
Old Aug 16, 2005 | 09:39 AM
  #68
TApimp's Avatar
Originally Posted by 777
I'm pretty sure that motor will not fit into your normal f-body
Its an iron block correct? then why wouldnt it fit? they would have to redo the plumbing, but i dont see why it would'nt fit.
Its a very impresive car, i know they built it to test the lsx motor out at the track.
what tire? raceweight?
Old Aug 16, 2005 | 09:42 AM
  #69
777's Avatar
777
The engine will fit, but have you seen the turbos and the piping. There's no way. Maybe this will clarify, notice that the car is a tube frame chasis and has no wheel wells (which we do have and takes up a considerable amount of space)
Old Aug 16, 2005 | 10:06 AM
  #70
GrahamHill's Avatar
That is just freaking awesome! Was it at pro street weight?
Old Aug 16, 2005 | 10:19 AM
  #71
TApimp's Avatar
I am going to quit trying......
Old Aug 16, 2005 | 10:29 AM
  #72
Kevin@W2W's Avatar
LS1TECH Sponsor
In car 6.86 video. Note the windshield buckle in high gear.
http://www.w2wpowertrain.com/images_...r_6.86_run.wmv
Old Aug 16, 2005 | 10:56 AM
  #73
V6 Bird's Avatar
Originally Posted by Kev@WheeltoWheel
In car 6.86 video. Not the windshield buckle in high gear.
Was this car just thrown together to make that pass or was it supposed to be a clean and neatly built car?
Old Aug 16, 2005 | 10:58 AM
  #74
777's Avatar
777
It's a work in progress. I'd say it's got more in it, but it's not the first run.
Old Aug 16, 2005 | 11:02 AM
  #75
V6 Bird's Avatar
I was only basing that on the wiring from the cockpit side.
Old Aug 16, 2005 | 11:15 AM
  #76
sb427f-car's Avatar
SSU'S Vice Mod
Originally Posted by 427
Not sure what the 352 will do next, but some engine dyno time is in order. According to the info collected, we are over 1900hp at the flywheel!!!
Kurt
Dang Kurt, that is impresive right there! Considering those Lencos soak up a fair amount of power, and I'm guessing that you're somewhere around 3000 lbs with Moran in the car, you're looking at about 1425 to the wheels? Unbelievable, congrats again.
Old Aug 16, 2005 | 11:17 AM
  #77
sb427f-car's Avatar
SSU'S Vice Mod
Originally Posted by Sandmann120
So, who will be the first to put a Gen III on blown nitro?
you are nuts. Probably have to wait for aftermarket 5 head bolt block and heads to try that though
Old Aug 16, 2005 | 11:25 AM
  #78
Kevin@W2W's Avatar
LS1TECH Sponsor
It's common practice to run wiring across the dash bar in a tube chassis vehicle and was existing prior to our work on it.
Old Aug 16, 2005 | 11:40 AM
  #79
Armageddon's Avatar
...with cheese.
Old Aug 16, 2005 | 12:45 PM
  #80
sb427f-car's Avatar
SSU'S Vice Mod
Originally Posted by Armageddon
Yeah, someone has horsepower envy
