need advice from people with Vortech exp
The kit should give you about 100 rear wheel horsepower. I would advise doing valvesprings, you'll love the extra power.
let me know how it goes.
make sure you get someone who knows how to tune good, the tune that vortech gives you is just something to get you in the ballpark.
I would not try to push the limits of the stock pistons any further. With the 6.0l heads you also have they are probably milled between .024 - .040 and will increase you effective compression ratio even further possibly by a point or even TWO.
FIRST, I would find out if IN FACT your heads were milled so adding 5 psi doesn't damage your engine. Figure out how much they were milled and then figure your static compression ratio to see if you're safe to run 5 psig of boost. You might have to run a Alcohol injection kit with your new Supercharger.
