T70 vs. T76... when to use which one?
Old Aug 17, 2005 | 04:27 AM
Ferocity02's Avatar
Arrow T70 vs. T76... when to use which one?
I am curious to the differences between the two besides the size obviously. Both seem to be pretty common LS1 turbos. I'd imagine that the T76 is capable of more power than the T70? Is the T70 a faster spooling turbo than the T76? Which one is more optimal for the street and which one for the strip? Thanks!
Old Aug 17, 2005 | 08:59 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
All depends on your goals my friend. A T70 will spool a little quicker then a T76 due to the fact of the smaller compressor wheel. The 76 will have more total flow though, due to the larger impeller. On a stock engine a T70 is more then enough to dust it and even a nice mild 650rwhp setup. BUT, if you are looking for 750-900rwhp, then a 76 is the only way to fly.
Jose
Old Aug 17, 2005 | 09:12 AM
Armageddon's Avatar
...with cheese.
my 70 was out of breath with the #'s in my sig. There was a little more timing on the table, I could have nosed off 650/700 with some effort I think. I've got a 76 coming thanks to our friend Jose^ I'm anxious to see how it performs.
Old Aug 17, 2005 | 10:38 AM
ddnspider's Avatar
yuo i got mine from our friend jose as well ^ i didnt want to max out the T70 and me and Armageddon have a few more cubes than stock so went with the T76GTS.for a stock motor a T70 would do nicely.
Old Aug 17, 2005 | 10:52 AM
Zombie's Avatar
The T70's are seem to work really good on a stock cube motor. I have a nasty habbit of turning up the boost though and put my 76 on the stock motor. I run 15 psi on the street now. If you want to run less than 14-15 psi I suggest the t70, the 76 for more boost or a larger motor.
