taping turbos for boost nipple
Old Aug 18, 2005 | 10:20 AM
will62085's Avatar
Default taping turbos for boost nipple
my Master Power T-70's have no provisions for hooking up to the wastegate. should i find a way to get a hose nipple on the boost side tubing? or drill and tap the turbo housing for the fitting? if the latter, where do i tap it?
Old Aug 18, 2005 | 10:25 AM
y2khawk's Avatar
either is acceptable. I've seen housings tapped near the start of the scroll and near the end/outlet of the housing. Honestly i don't know if there's any pressure difference between the start and end of the scroll (ideally there shouldn't be) but you never know with moving air.
I tend to put it near the exit of the housing if possible.
Old Aug 18, 2005 | 10:28 AM
will62085's Avatar
thanks, and what about a 1/8 NPT should do it right?
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Tap it at either the end of the compressor cover discharge, or on the scroll itself. Here is an example of one on the scroll.
Jose
Old Aug 18, 2005 | 10:32 AM
will62085's Avatar
thanks jose, one more question, any clamps or anything to hold the hose on? and regular vacumm line will work right?
Old Aug 18, 2005 | 10:34 AM
LS1TECH Sponsor
Yeah regular line will work. As for holding it on...simple and easy is zip tie. If you don't like that, then get a screw-in clamp, but zip tie is quick and easy.
Jose
Old Aug 18, 2005 | 10:45 AM
y2khawk's Avatar
That's what I always use. letter drill R for the tap.
Old Aug 18, 2005 | 11:18 AM
turbocuda's Avatar
R may be the precise bit size but 5/16 bit can be used in its place. We tap probably 1000 holes a month here at work...no problems and probably easier to find.
1/4 npt- we use 7/16
1/8 npt- we use 5/16
Here is some of the stuff we build.
Old Aug 18, 2005 | 01:01 PM
cablebandit's Avatar
atpturbo.com has some fittings made to go into the silicone hose just for this purpose so you dont have to drill the housing
