Some Phamspeed install pics
Old Aug 21, 2005 | 05:09 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Some Phamspeed install pics
Here are some pics of PurEvl's car coming together.We made a bracket to hold the Turbo so it won't put any stress on the pipes.Then we cut out the front to move the radiator's so he could use the stock dual fans
Old Aug 21, 2005 | 05:28 PM
69firebird's Avatar
looks good
Old Aug 21, 2005 | 05:29 PM
frcefed98's Avatar
Nice, great to see the t88/pham kit going on mikes ride.
Is that the brace I see going to the front of the block? Any worries that it'll break the block in those areas...or not a worry at all?
Man its going to be one sick ride...like always until he gets an itch to change it again
More pics of the brace please, I know my headers are living on borrowed time with the 45lb GT42 hanging off em.
Thanks,
Jeremy
Old Aug 21, 2005 | 05:33 PM
Josh@KY-Turbo's Avatar
is that the single turbo kit with the headers they dont make anymore?
Old Aug 21, 2005 | 05:34 PM
frcefed98's Avatar
oh yeah, slowhawk, I just ordered a 2.5 inch flex bellows for the long passenger side crossover pipe. I plan on cutting the pass side crossover in two pieces about 6 inches from the outlet of the passenger side header and splicing it in right there to isolate the load and movement thats going to the headers....good idea or bad...let me know.
J
Old Aug 21, 2005 | 05:47 PM
Slowhawk's Avatar
LS1Tech Sponsor
What you don't see in the picture is the second bolt holding the bracket on under the power steering.The bracket is strong as hell and took my 230lbs standing on it The only thing that I wonder about is the Turbo being 1/4" away from the pulley.We hope it doesn't melt the rubber in the pulley
Old Aug 21, 2005 | 05:49 PM
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by frcefed98
oh yeah, slowhawk, I just ordered a 2.5 inch flex bellows for the long passenger side crossover pipe. I plan on cutting the pass side crossover in two pieces about 6inches from the out let of the passenger side header and splicing it in right there to isolate the load and movement thats going to the headers....good idea or bad...let me know.
J
Sounds good.We need to move the pass side up about 1" but may be limited on engine movement.The flex is a good idea
Old Aug 21, 2005 | 06:57 PM
frcefed98's Avatar
Cool I'll proceed with that mod...was unsure but I want to keep the stress off this header. I wished pham thought parts of this kit out a lil better
I haven't melted my balancer pulley yet, I have a turbonetics heatshield on the exhaust housing so that helps a lil i'd think, and I also coated it too. I want to get the better exhaust housing blanket Jose sells once I have the money for it.
I'll try and fab up a brace for my turbo as well, don't want the cracks to start forming, thanks for the great idea to where it should go
J
Old Aug 21, 2005 | 09:18 PM
Slowhawk's Avatar
LS1Tech Sponsor
J
Shoot me some pics of the exhaust when your done.Pics alway's give me idea's
We are also doing an oil pump for the return after seeing alot of drain back problems but we will add a resister to slow down the pump so it lives longer
Old Aug 21, 2005 | 09:55 PM
frcefed98's Avatar
Here is some pics of the exhaust how it is now,
In the first pic, i've added in where I'll put the flex bellows on the passenger side crossover. I have a 3.0 flex bellows on the DP already. The exhaust is tucked up real nice and hasn't banged anything...only the damn passenger side crossover pipe has
I welded a tab on to the "catalytic" pipe right where GM has the hanger off the tranny I then drilled a hole through the tab and into the tranny bracket itself, put a bolt, lock washer and nut through to keep the exhaust bolted up to the tranny bracket and off the BMR T/A mount. I'll have to get pics of that as its not in these pics. Real slick as I can go open DP by taking off the catback strap clamp, a strap clamp off the DP and taking out the bolt to the tranny bracket...literally 10-15min of work at the track....when I get there
J
Attached Thumbnails Some Phamspeed install pics-dsc06322.jpg   Some Phamspeed install pics-dsc06313.jpg
Old Aug 21, 2005 | 10:03 PM
NA$TY-TA's Avatar
lOOKS GOOD.... How much longer till shes togeather?? You guys ahve a set date to be doen by?? Waiting on anything?? What WG u guys using??
Kyle
Old Aug 22, 2005 | 07:30 AM
Slowhawk's Avatar
LS1Tech Sponsor
Kyle
Don't know when it will be done.I'm so busy at the shop right now bvuilding some other cars.I figure I need 3-4 more day's to get this done.So I'm hoping 2 weeks or so
Old Aug 22, 2005 | 07:43 AM
RealQuick's Avatar
looks nice...
Old Aug 22, 2005 | 10:38 AM
PurEvl's Avatar
its coming along...cant wait
Old Aug 22, 2005 | 11:21 AM
CHRISPY's Avatar
Looks great!
How long did it take to cut out the front brace to move the fans? Did you weld or bolt in the new cross piece?
Old Aug 22, 2005 | 11:38 AM
PurEvl's Avatar
its welded in
Old Aug 22, 2005 | 05:27 PM
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by CHRISPY
Looks great!
Lot's of measuring,thinking,cutting and welding
Old Aug 22, 2005 | 06:40 PM
pdd's Avatar
pdd
LOOKS GREAT
