SDCE set up with ATI damper
Old Aug 25, 2005 | 10:06 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Default SDCE set up with ATI damper
I am going with the SDCE spring tensioner, my question is which ATI damper is recommended with this set up: The OEM size or the 10% underdrive. Oh by the way is SDCE still a sponsor? Thanks in advance.
Old Aug 25, 2005 | 10:16 PM
1bad2k2ta's Avatar
I assume you want to keep your A/C and I would not recommend the underdrive in Texas, it is too hot and you will need all the cooling you can get. You would want part# 917264. It's the 7.5" aluminum damper with the A/C pulley included. Not cheap either, around $480. I would also recommend the crank pin kit to keep the damper from spinning on the crank should the crank bolt not hold it. This is fairly common. Not sure how much the kit is as I had my crank keyed for it when the motor was machined.
Old Aug 25, 2005 | 10:33 PM
Yes sir A/C must stay. Yeah I know this will be $500.00+, but do it right the first time and get it over with. The crank will be pinned also. Thanks for the reply.
Old Aug 26, 2005 | 06:09 AM
EPP's Avatar
EPP
The crank pinning kit is approx $110.00. Bob
Old Aug 26, 2005 | 07:02 AM
Thanks Bob.
